Using a fan to cool down small sections
Posted by B4Me
August 21, 2012 04:42PM
Hi
I have been trying to getting used to skeinforge for some weeks now, after been using slic3r for some time..
I was trying to get skeinforge to work as simulare to slic3r as possible, but cant seem to get my fan to ONLY run when its needed to cool small sections AND bridges sad smiley
When its running from start to end, it cools my build platform and makes the object separate and so on sad smiley
So.. is there a "hack" or some function I could use to get a "slic3r" behavior from my fan ?
Re: Using a fan to cool down small sections
August 22, 2012 05:57AM
The only solution I know is to use the "orbit" cool method and put
M106 S255
in your cool_start.gcode alteration file, and
M107
in cool_end.gcode.
Far from perfect because
1) the fan will only work during orbiting cooldown period.
2) orbiting is problematic because it let time for nozzle oozing.
It maybe possible to make it work by combining with "Wipe" module, but I didn't investigate that.
If someone wants to hack the cool module, it would be nice to add a third cool method, "FAN" (trigger fan if layer time is below "Minimum layer Time (seconds)").
Or even better keep using the slowdown method as is ; and add a couple of times parameter "Max layer time for fan" (minimum speed of the fan, fan is off if layer printing time is longer than this) and "Full fan speed layer time" (any layer shorter than this will have fan running full speed).
The PWM - when available - would gradually adapt fan speed between those 2 boundaries.
August 22, 2012 06:48AM
If I just knew how to write a plugin in python sad smiley
August 22, 2012 06:56AM
Fan on during overhanging layers would be more useful. I don't need a fan for small layers, I just slow right down to a standstill but I can't do anything with convex of concave overhangs because the edges curl upwards.
August 22, 2012 07:18AM
nophead idea is good, but in the meantime I did it as I first described, if someone want to test... No warranty.
Backup your original cool.py, and replace it with the file attached (renaming it to "cool.py") (and remove the cool.pyc if present).
open | download - cool_fan_control.py (19.7 KB)
August 22, 2012 07:46AM
I will test as soon as I get home from work grinning smiley
August 22, 2012 08:02AM
Oh, you also have to untick "Turn fan on at beggining", I made my change only apply if this is not enabled.
Next enhancement would be "No fan before..." Should that be layer X or height Z mm ?
And then I'll turn to overhang detection, which I have not a single clue how to achieve currently. I'll study how the bridge detection is done, maybe I could cook up something similar.
August 22, 2012 08:04AM
In slic3r its n-layers
which in my opinion makes most sense, as I the can change it depending on my layer height
Edited 1 time(s). Last edit at 08/22/2012 08:12AM by B4Me.
August 22, 2012 01:00PM
Here's another version, with the "do not use fan before layer n" option.
open | download - cool_fan_control_2.py (20 KB)
August 22, 2012 03:06PM
Its working ! grinning smiley
beautifully grinning smiley
Slic3r go home ! grinning smiley
August 22, 2012 04:18PM
What did you print for a test ? We all love prints pictures winking smiley
August 22, 2012 07:01PM
Off cause smiling smiley
This new (black) fan duct, so I get uniform air instead of only from the right side
August 22, 2012 07:10PM
Cooling with a fan is so overrated tongue sticking out smiley
No really I find it does more bad than good. (warping etc.)
But fan or additional cooling for bridges is "cool".
Btw: In SF overhangs are detected as bridges and treated as such so You can add your fan command to the bridging part...
www.reprapfordummies.net
IRC: #reprap on freenode.net (Action68)
[github.com]
August 23, 2012 03:22AM
Ahmet, thanks for the info, will help.
B4me, what is the source for that fan duct ? I might consider making myself one.
August 23, 2012 04:08AM
Its from here, but not ideal...
[tinkercad.com]
Had to redrill the mount holes.. and I super glued my fan on to it smiling smiley
August 27, 2012 10:52AM
Here's a first step toward Nophead's request, new version use the bridge detection of the Inset module - you must activate "Infill in direction of Bridge" there first.
Then you can tick the new "Force Fan on Bridge Layers" box in Cool.
Not tested a lot.
Trying to explain priorities :
1) if "Turn Fan On at Beginning", well then fan is always on.
2) if "Force Fan on Bridge Layers" and layer is detected as a bridge, fan is activated.
3) after that only, "No Fan use before Layer" is checked. Yup it means even second layer will get some air if it's a bridge.
4) then the max and full speed duration of layer settings apply to calculate fan speed (and the time used here is the duration of the layer before cool slowdown is applied).
open | download - cool_fan_control_3.py (20.1 KB)
December 02, 2012 09:41PM
I haven't had any luck with this download.
It would really be nice to be able to turn on the fan either after or on the x'th number layer- especially if that could be integrated into repetier host some how.
December 04, 2012 09:01AM
Doesn't Repetier host come with Slic3r nowadays ? And I believe Slic3r have that feature.
I reckon that's a lot of belief and guess.
5 minutes and a few mouseclicks later : belief and guesses were right.
open | download - Slic3r is cool too.jpg (99.7 KB)
December 06, 2012 09:27PM
Thanks but I use Skeinforge
December 07, 2012 05:52AM
Ok, then explain what is your problem with my modified skeinforge plugin "cool_fan_control_3.py", I have had the occasion to test it now so I can confirm it works and maybe we could help you.
February 05, 2013 02:47PM
Hi DeuxVis and THANK you for such great plug in.
I was testing bridging today, and I had a bridge lower than the "No Fan use before Layer" and the fun did not start.
I tested it only once though. Just wanted to let you know.
Thanks again
June 19, 2013 08:02AM
I really like your variant of the cool plugin. But I missed one setting and therefore I modified it a bit.
Now it is possible to set the maximum fan speed. In my case all the settings were as desired but full fan speed was just too much.
Futhermore i changed the layout to have the priorities of the fan settings clear.
open | download - cool_fan_control_4.py (20.4 KB)
September 16, 2013 05:21PM
It always seems to use 200 for the fan PWM value regardless of what is in the text field. It gets saved in the file but it always returns to 200 when the settings are loaded. Looking at the code I can't see any reason in the code as it looks the same as the other integer fields.
September 16, 2013 07:46PM
Had to capitalise "Fan" and "Speed" on this line: -
self.fanmaxPWM = settings.IntSpin().getFromValue(0, 'Full Fan Speed (0 - 255):', self, 255, 200)
Skeinforge stores the full name in the config files but does some insane reduction to smallest unique keys that goes wrong when two properties start with the same substring but in different cases. It ended up mixing it up with this one:
self.fullFanLayerTime = settings.FloatSpin().getFromValue(0.0, 'Full Fan Speed Bellow Layer Time (seconds):', self, 240.0, 20.0)
Wasted hours tracking that down.
October 10, 2013 09:49AM
nophead, that's strange, it did not affect me - I'm 100% positive on that as my fan will only buzz instead of turning if you give him anything below 255, I would need to give it a capacitor in order to work on PWM.
Thanks for reporting your findings anyway.
October 10, 2013 10:46AM
Are you using Joost-b's version or your own?
November 07, 2013 05:23AM
I was using mine, sorry for the misunderstanding.
December 11, 2013 11:47AM
A new version with a new setting : minimum movement speed when using slowdown cool type.
Sometimes extreme slowdowns seems to be more harmful than helpful (for instance when printing the top of a pyramid).
Edit : oops nearly forgot to do it, while I was on it, changed the caps thing as reported by nophead.
Edited 1 time(s). Last edit at 12/11/2013 11:53AM by DeuxVis.
open | download - cool_fan_control_5.py (20.8 KB)
January 05, 2014 02:46PM
I never had many successes in printing small parts. Really when I print pieces less than 0.5x 0.5 cm PLA melts down.
In order to minimize this effect I tried:
- SLOW DOWN
> does not help much: it seems to me that THE MORE THE HEAD IS NEAR THE PLASTIC, THE MORE IT HELPS THE MELTING PROCESS (the head is hot)
- FAST PRINT
> seems good. But then ? If the part is small, in 2 seconds the layer is done, but if the heads go on the following layer, then the head helps to MELT what was good
- ORBITING / MOVING HEAD to loose time.
> very bad experience: the print becomes SLOOooooowwww..., and the nozzle starts to oozing and then the print quality is lost. No way to step back the filament, because then it will create issue starting the new layer.
- COOLING
I put 2 (!) 10 cm fan; one on top pointing the air flux on the center of the platform (air top->down center) , one on left pointing the flux at the center of platform (air left->center) and a BIG VORTEX FAN 50 cm away pointing to the printer, trying to print the famous tower test.
> I think I damaged the printer controller board usb (!). In fact the electrical disturbance of 3 motors on the power line, caused the laptop to have continuous disconnect errors (and since then I was never able to have any print without random usb disconnect). Note that the fans were self powered outside the printer power supply, but however on the same home line plug.
> improvements on the quality of the print, but not perfect, lot of noise and air. I was using 3 & 1 big fan, and that was just enough to some improvements.
So I am still trying to find the magic formula, may be, software controlled low temperature of nozzle during small pieces, and software controlled fan ON/OFF, AND .....
* A plastic air conveyor to drive the fan air on the specific area of the nozzle
* A mini VACUUM device mounted in some manner to the nozzle to create vacuum and prevent plastic to ooze during a cool phase software controlled.
I keep you informed of progresses.
BR
January 05, 2014 05:12PM
The top of this prints OK on a Mendel90 [www.thingiverse.com] and that is only a 5mm cube. I just slow down and have a ducted fan. I am not sure how much smaller would work with PLA but if I had to print something very small I would either use ABS or print a sacrificial 5mm tower at the same time located as close as possible to the small bit.
