Does anyone know of an alternative support material plugin?
It took me the better half of a day to get usable settings with SF50.
I ended up with a feed rate ratio of 0.0025 to get the base layer to run at the same speed as my print feed rate.
The settings affect each other in a way that just does not make sense.
It's also generating support material completely outside of the model that supports no part of the model, and above an area that needed support, up past the support/model interface. Example of a sphere, I most certainly do not need support material on the top of the sphere.
The pieces I am wanting to print, I have to use Everywhere setting to get full model support.
I get better support with KISSlicer, but it is not as clean slicing in some areas as SF.
Edited 2 time(s). Last edit at 11/19/2012 01:06PM by Dirty Steve.
