Generating dual head G-code issue with M104
Posted by Adventure
January 20, 2013 09:39PM
I have this in my start.gcode file.
M104 S175 T1(Set extruder target temp PVA support)
M104 S215 T0(Set extruder target temp)
After I generate the g-code using Skeinforge 50 I get this:
Why is Skeinforge removing my second temp????? I have looked at everything and have no idea why this is hapening.
Thanks
Jeff
Re: Generating dual head G-code issue with M104
January 21, 2013 12:17AM
Check your alterations plugin to see if you have "remove redundant code" checked. This will cause this to happen. See here.
January 21, 2013 10:12AM
Thank you for your help, I will try it out.
Jeff Christiana
January 21, 2013 02:53PM
That worked.
Thanks
Jeff Christiana
