Re: Skeinforge Powwow October 06, 2009 12:31PM |
Re: Skeinforge Powwow October 06, 2009 03:45PM |
Re: Skeinforge Powwow October 06, 2009 04:41PM |
Re: Skeinforge Powwow October 07, 2009 04:16AM |
Re: Skeinforge Powwow October 07, 2009 04:34AM |
Re: Skeinforge Powwow October 07, 2009 06:45AM |
Re: Skeinforge Powwow October 07, 2009 04:53PM |
Re: Skeinforge Powwow October 08, 2009 12:45AM |
Re: Skeinforge Powwow October 09, 2009 08:18AM |
Re: Skeinforge Powwow October 09, 2009 08:25AM |
Admin Registered: 16 years ago Posts: 13,874 |
Re: Skeinforge Powwow October 09, 2009 09:34AM |
Admin Registered: 17 years ago Posts: 7,879 |
Re: Skeinforge Powwow October 09, 2009 11:12AM |
Re: Skeinforge Powwow October 14, 2009 10:51PM |
Re: Skeinforge Powwow October 20, 2009 09:55AM |
Re: Skeinforge Powwow October 21, 2009 11:44AM |
Re: Skeinforge Powwow October 22, 2009 03:58AM |
Re: Skeinforge Powwow October 22, 2009 04:17AM |
Re: Skeinforge Powwow October 22, 2009 12:48PM |
Re: Skeinforge Powwow October 22, 2009 01:05PM |
Re: Skeinforge Powwow October 22, 2009 02:36PM |
Re: Skeinforge Powwow October 23, 2009 06:35AM |
Re: Skeinforge Powwow October 26, 2009 12:23AM |
Re: Skeinforge Powwow October 31, 2009 10:48AM |
~/reprap_python_beanshell$ ./skeinforge.py ~/Desktop/y-bar-clamp_10off.stl File /home/mccoyn/Desktop/y-bar-clamp_10off.stl is being chain exported. Carve procedure took 5 seconds. Preface procedure took 0 seconds. Inset procedure took 13 seconds. Fill procedure took 25 seconds. Speed procedure took 2 seconds. Comb procedure took 10 seconds. Clip procedure took 2 seconds. Cool procedure took 5 seconds. Stretch procedure took 3 seconds. Home procedure took 3 seconds. Lash procedure took 2 seconds. Fillet procedure took 5 seconds. The lower left corner of the behold window is at 0.089, 0.2 The upper right corner of the behold window is at 23.908, 23.801 The lower left corner of the skeinview window is at 0.089, 0.2 The upper right corner of the skeinview window is at 23.908, 23.801 Statistics are being generated for the file /home/mccoyn/Desktop/y-bar-clamp_10off_export.gcode On the X axis, the extrusion starts at 0 mm and ends at 24 mm, for a width of 24 mm. On the Y axis, the extrusion starts at 0 mm and ends at 24 mm, for a depth of 24 mm. On the Z axis, the extrusion starts at 0 mm and ends at 14 mm, for a height of 13 mm. The average feedRate is 52.4 mm/s, (3141.1 mm/min). The cross section area is 0.402 mm2. The extrusion diameter is 0.715 mm. The extruder speed is 3000.0 The extruder was extruding 72.2 percent of the time. The extruder was toggled 500 times. The layer thickness is 0.65 mm. The operating flow rate is 24.1 mm3/s. The perimeter extrusion fill density ratio is 1.06 The perimeter width is 0.585 mm. The following procedures have been performed on the skein: carve preface inset fill speed comb clip cool stretch home lash fillet The text has 16993 lines and a size of 556.0 KB. The total build time is 321 s. The total distance extruded is 12139.7 mm. The total distance traveled is 16813.5 mm. The version is 2009-10-14 The volume extruded is 4.87 cc. The exported file is saved as /home/mccoyn/Desktop/y-bar-clamp_10off_export.gcode It took 87 seconds to export the file.
Re: Skeinforge Powwow November 03, 2009 02:47PM |
[arhimed@gedora10 Skeinforge]$ ./skeinforge.py Skeinforge preferences have been saved. File /home/arhimed/PRINT/MENDEL/_fixed_x-180-z-bearing-plate_2off (fixed).stl is being chain exported. Carve procedure took 3 seconds. Preface procedure took 0 seconds. Inset procedure took 20 seconds. Exception in Tkinter callback Traceback (most recent call last): File "/usr/lib64/python2.5/lib-tk/Tkinter.py", line 1403, in __call__ return self.func(*args) File "/home/arhimed/Dev/Skeinforge/skeinforge_tools/skeinforge_utilities/preferences.py", line 1529, in execute self.repository.execute() File "./skeinforge.py", line 290, in execute writeOutput( fileName ) File "./skeinforge.py", line 267, in writeOutput craft.writeOutput( fileName ) File "/home/arhimed/Dev/Skeinforge/skeinforge_tools/craft.py", line 69, in writeOutput pluginModule.writeOutput( fileName ) File "/home/arhimed/Dev/Skeinforge/skeinforge_tools/craft_plugins/export.py", line 136, in writeOutput gcodeText = consecution.getChainTextFromProcedures( fileName, procedures[ : - 1 ], gcodeText ) File "/home/arhimed/Dev/Skeinforge/skeinforge_tools/skeinforge_utilities/consecution.py", line 39, in getChainTextFromProcedures text = craftModule.getCraftedText( fileName, text ) File "/home/arhimed/Dev/Skeinforge/skeinforge_tools/craft_plugins/fill.py", line 407, in getCraftedText return getCraftedTextFromText( gcodec.getTextIfEmpty( fileName, text ), fillRepository ) File "/home/arhimed/Dev/Skeinforge/skeinforge_tools/craft_plugins/fill.py", line 417, in getCraftedTextFromText return FillSkein().getCraftedGcode( fillRepository, gcodeText ) File "/home/arhimed/Dev/Skeinforge/skeinforge_tools/craft_plugins/fill.py", line 1107, in getCraftedGcode self.addFill( layerIndex ) File "/home/arhimed/Dev/Skeinforge/skeinforge_tools/craft_plugins/fill.py", line 981, in addFill self.addGrid( arounds, fillLoops, gridPointInsetX, layerIndex, paths, aroundPixelTable, aroundWidth, reverseZRotationAngle, surroundingCarves ) File "/home/arhimed/Dev/Skeinforge/skeinforge_tools/craft_plugins/fill.py", line 999, in addGrid gridPoints = self.getGridPoints( fillLoops, reverseZRotationAngle ) File "/home/arhimed/Dev/Skeinforge/skeinforge_tools/craft_plugins/fill.py", line 1160, in getGridPoints self.addGridLinePoints( begin, end, gridPoints, gridRotationAngle, offset, y ) File "/home/arhimed/Dev/Skeinforge/skeinforge_tools/craft_plugins/fill.py", line 1033, in addGridLinePoints if self.isPointInsideLineSegments( gridPointComplex ): File "/home/arhimed/Dev/Skeinforge/skeinforge_tools/craft_plugins/fill.py", line 1199, in isPointInsideLineSegments lineSegments = self.horizontalSegmentLists[ fillLine ] IndexError: list index out of range [arhimed@gedora10 Skeinforge]$ rpm -qa | grep -i tkinte tkinter-2.5.2-1.fc10.x86_64 [arhimed@gedora10 Skeinforge]$ python --version Python 2.5.2 [arhimed@gedora10 Skeinforge]$
Re: Skeinforge Powwow November 03, 2009 03:02PM |
Re: Skeinforge Powwow November 03, 2009 11:29PM |
Re: Skeinforge Powwow November 04, 2009 07:04AM |
Re: Skeinforge Powwow November 04, 2009 07:32AM |
Re: Skeinforge Powwow November 04, 2009 09:29AM |
Re: Skeinforge Powwow November 04, 2009 11:18AM |
