I am trying to print an arc like object that I need to print supports for. I do not feel that I need to print a raft under it and the bottom is also smoother if it is directly on the bed.
I have set Skeinforge Raft module so that the raft and interface layer counts are zero. Normally my first layer starts at Z=0.2 mm, but for whatever reason with Raft doing the supports the first layer starts at Z=0.6 mm (with layer height being 0.4 mm). This causes the filament not to stick to the bed and cause the print to fail.
I think the Raft module thinks there should be a raft layer at Z=0.2, so it starts the actual print at one layer higher. However I have seen people being instructed to tell Raft make a support with 0 raft/interface layers.
I could just try enabling raft/interface layers, but I am interested in knowing the real reason behind this problem...
What parameters should I tweak in order to be able to print supports properly the way I want?
My Raft module config
Add Raft, Elevate Nozzle, Orbit: True
Base Feed Rate Multiplier (ratio): 1.0
Base Flow Rate Multiplier (ratio): 1.0
Base Infill Density (ratio): 0.5
Base Layer Thickness over Layer Thickness: 2.0
Base Layers (integer): 0
Base Nozzle Lift over Base Layer Thickness (ratio): 0.2
Initial Circling: False
Infill Overhang over Extrusion Width (ratio): 0.05
Interface Feed Rate Multiplier (ratio): 1.0
Interface Flow Rate Multiplier (ratio): 1.0
Interface Infill Density (ratio): 0.5
Interface Layer Thickness over Layer Thickness: 1.0
Interface Layers (integer): 0
Interface Nozzle Lift over Interface Layer Thickness (ratio): 0.5
Name of Support End File: support_end.gcode
Name of Support Start File: support_start.gcode
Operating Nozzle Lift over Layer Thickness (ratio): 1.0
Raft Additional Margin over Length (%): 1.0
Raft Margin (mm): 3.0
Support Cross Hatch False
Support Flow Rate over Operating Flow Rate (ratio): 1.0
Support Gap over Perimeter Extrusion Width (ratio): 1.0
None False
Empty Layers Only False
Everywhere True
Exterior Only False
Support Minimum Angle (degrees): 45.0
