Support without Raft, first layer starts too high June 13, 2013 06:05PM |
My Raft module config
Add Raft, Elevate Nozzle, Orbit: True
Base Feed Rate Multiplier (ratio): 1.0
Base Flow Rate Multiplier (ratio): 1.0
Base Infill Density (ratio): 0.5
Base Layer Thickness over Layer Thickness: 2.0
Base Layers (integer): 0
Base Nozzle Lift over Base Layer Thickness (ratio): 0.2
Initial Circling: False
Infill Overhang over Extrusion Width (ratio): 0.05
Interface Feed Rate Multiplier (ratio): 1.0
Interface Flow Rate Multiplier (ratio): 1.0
Interface Infill Density (ratio): 0.5
Interface Layer Thickness over Layer Thickness: 1.0
Interface Layers (integer): 0
Interface Nozzle Lift over Interface Layer Thickness (ratio): 0.5
Name of Support End File: support_end.gcode
Name of Support Start File: support_start.gcode
Operating Nozzle Lift over Layer Thickness (ratio): 1.0
Raft Additional Margin over Length (%): 1.0
Raft Margin (mm): 3.0
Support Cross Hatch False
Support Flow Rate over Operating Flow Rate (ratio): 1.0
Support Gap over Perimeter Extrusion Width (ratio): 1.0
None False
Empty Layers Only False
Everywhere True
Exterior Only False
Support Minimum Angle (degrees): 45.0
Re: Support without Raft, first layer starts too high June 14, 2013 11:24AM |
