My irritation is that when Skeinforge slices an STL it sets the initial travel speed moving from home to the start of the skirt to F60.0
This is dramatically slower than the rest of the print - layer 1 is F1200, and subsequent layers are F3000.
I can't find a setting to fix this and have to edit the gcode manually each time.
Does anyone know where I can fix this?
It's set after gcode.start, so altering it in this doesn't make any difference.
A fairly typical example of the line in question:-
G1 X58.614 Y40.69 Z0.3 F60.0
Thanks
David
Setup: Prusa hosted by Ubuntu 12.04 running Repetier-host and a Sanguinolulu board running Sprinter firmware.
Slicing with: Skeinforge 12.03.14
