Good Day,
I just want to ask how to avoid holes in your 3D print in skeinforge.
(See first image).
I printed the same object in makerbot same settings and the print doesn't have any holes in it.
(See second image).
My setting in skeinforge:
Carve:
Edge with over height ratio: 2.67
Extra decimal places: 1.0
import coarsness: 1.0
layer height: 0.15
layers:
layer from: 0
layers to: 912345678
Mesh type: correct mesh
Fill:
Diagphram:
Diagphram period: 100
Diagphram thickness: 0
Extra shells
Extra shells on alternating solid later: 1
Extra shells on base 1
Extra shells on sparse layer 1
Grid
Grid circle separation over perimeter width: 0.2
Grid extra overlap 0.1
Grid junction separation band height 10
Grid junction separation over octagon radius at end 0
Grid junction separation over octagon radius at middle 0
infill:
infill begin rotation 45
infill begin rotation repeat
infill odd layer extra rotation 90
infill patern
Grid rectangular
infill perimeter overlap :0.15
infill solidity 0.2
sharpest angle degrees: 60
solid surfae thinckness 5
start from choice nearest
surrounding angle 60
thread sequence choice loops>perimeter>infill
SPEED
bridge feed rate multiplier 1.2
bridge flow rate 0.9
duty cyle
Duty Cyle at beginning 1.0
Duty cyle at ending 0.0
Feed Rate 30.0
Flow rate setting 1.3511
Object first layer
Object first layer feed rate infill multipier 0.1
Object first layer feed rate perimeter multipier0.1
Object first layer flow rate infill multipier 0.4
Object first layer flow rate perimeter multipier 1.0
travel feed rate 30.0
Settings:
Object infill: 0
layer height:15%
number of shells: 1
Feedrate: 40
Travel Feedrate: 70
Print temperature: 230
Plastic:
Filament diameter 1.82
Extruder:
nozzle diamter .4
And my settings for makerbot
Quality:
Infill: 0%
Number of shells: 1
layer height: 0.15
Temperature:
left extruder 230c
build plate: 105c
Speed:
Speed while extruding 40mm/s
Speed while traveling 70mm/s
Im using flashforge Creator
Edited 1 time(s). Last edit at 01/20/2014 03:20AM by tykola.
