What's with all these solid layers?
Posted by Jonny1983
February 04, 2014 11:13AM
I've printed an Ocarina from a stl from Thingiverse and it came out with a pattern across the Z axis.
Upon inspection I cound the darker lines are caused by solid slices in the gcode. I can't figure out why this is happening, I've played around with the Surrounding Angle in the Skeinforge Fill tab (it maxes out at 80) and it hasn't made a difference.
Can anyone point me the right direction?
Below is a link to my print.
[www.thingiverse.com]
Below is the stl
[www.filedropper.com]
Below is the gcode
Edited 1 time(s). Last edit at 02/04/2014 11:14AM by Jonny1983.
Re: What's with all these solid layers?
February 04, 2014 12:02PM
Its a setting called infill in direction of bridge. If you un-check it the extra solid layers will go away. But SF will still skip the extra perimeters on those layers.
February 05, 2014 06:50AM
In SFACT there is the option to add extra perimeters for bridge Layers.
[github.com]
February 05, 2014 11:25AM
Sublime
Ah, didn't realise there was a setting for that. I'll give it a go when I get home.
ahmetcemturan
Which tab does this come under? Is it in a specific version? I can't seem to find the option.
