nophead Wrote:
> In my software I have a separate setting for
> everything on the first layer: bed temp, plastic
> outline temp, plastic fill temp, outline speed,
> fill speed, fan on or off.
> All this stuff should be separate from slicing
> though as it is with my system. You should not
> have to slice the model again to change speeds and
> temperatures.
If people starts to using heated build platform, why not add this "first layer options" to Skeinforge?
I see this as another filter, were we can use it or simple disable. Like that it would also work as you need.
New cutting edge RepRap electronics, ARM 32 bits @ 100MHz runs RepRap @ 725mm/s:
www.3dprinting-r2c2.com]
