extruded strands outside object
Posted by MarcusWolschon
January 23, 2010 11:31AM
Any idea what I could do about these?
* homeprototype free 3d design repository
* Blog
* Google+
open | download - skeinforge.jpg (45.7 KB)
Re: extruded strands outside object
January 23, 2010 03:10PM
Try the latest version at:
[members.axion.net]
If there is still a problem when asking for help please include your object and your zipped skeinforge preferences. The skeinforge preferences are in the .skeinforge folder in your home directory. If you include your object and zipped preferences, I will give your bug a high priority. If you do not I will give it a low priority since without the object and zipped preferences I often can not reproduce the bug.
January 23, 2010 03:23PM
Ah, again a new version. (2010-01-22 instead of my 2010-01-20)
Thanks.
I just tried it and the issue still exitst.
The object and skeinforge-settings are attached to this message.
(profile is any of the two ABS-bfb)
Is there some kind of changelog to see what has changed
between skeinforge-versions? Or a blog to see what parts are
currently being worked on?
* Blog
* Google+
open | download - buckle_male_rev5_cleaned.stl (58.1 KB)
open | download - skeinforge_settings.zip (35.7 KB)
January 23, 2010 08:25PM
The problem was your Infill Perimeter Overlap at 1 was way too high. From the fill documentation:
"====Infill Perimeter Overlap====
Default is 0.15.
Defines the amount the infill overlaps the perimeter over the average of the perimeter and infill width. The higher the value the more the infill will overlap the perimeter, and the thicker join between the infill and the perimeter. If the value is too high, the join will be so thick that the nozzle will run plow through the join below making a mess, also when it is above 0.7 fill may not be able to create infill correctly. If you want to stretch the infill a lot, set 'Path Stretch over Perimeter Width' in stretch to a high value."
There is no changelog.
The blog is at:
[fabmetheus.blogspot.com]
January 24, 2010 01:53AM
thanks a lot.
My infill did not touch the shell,
so I experimented and must have misread
the page at
[www.bitsfrombytes.com]
(the one it openes when pressing (?))
* Blog
* Google+
