Attempt to print test cube, print blobs and infill instead August 10, 2010 10:31PM |
Re: Attempt to print test cube, print blobs and infill instead August 11, 2010 01:06AM |
Re: Attempt to print test cube, print blobs and infill instead August 11, 2010 09:30AM |
Re: Attempt to print test cube, print blobs and infill instead August 11, 2010 10:49PM |
Re: Attempt to print test cube, print blobs and infill instead August 12, 2010 02:43AM |
Admin Registered: 17 years ago Posts: 7,879 |
Re: Attempt to print test cube, print blobs and infill instead August 12, 2010 04:12AM |
Re: Attempt to print test cube, print blobs and infill instead August 12, 2010 10:05AM |
Re: Attempt to print test cube, print blobs and infill instead August 16, 2010 11:17AM |
Re: Attempt to print test cube, print blobs and infill instead August 16, 2010 11:32AM |
Re: Attempt to print test cube, print blobs and infill instead August 16, 2010 03:52PM |
Re: Attempt to print test cube, print blobs and infill instead August 16, 2010 05:22PM |
Re: Attempt to print test cube, print blobs and infill instead August 16, 2010 07:55PM |
Re: Attempt to print test cube, print blobs and infill instead August 16, 2010 10:50PM |
Re: Attempt to print test cube, print blobs and infill instead August 17, 2010 05:24AM |
Re: Attempt to print test cube, print blobs and infill instead August 17, 2010 08:06AM |
Re: Attempt to print test cube, print blobs and infill instead August 17, 2010 08:16AM |
Re: Attempt to print test cube, print blobs and infill instead August 17, 2010 08:43AM |
Re: Attempt to print test cube, print blobs and infill instead August 17, 2010 09:10AM |
Prerequisites
The Host software is still a little buggy on Windows with Java 6 installed, if you encounter any problems with Java 6 and the software, try uninstalling Java 6 and install the latest Java 5 runtime from:
[java.sun.com]
Re: Attempt to print test cube, print blobs and infill instead August 17, 2010 09:58AM |
Re: Attempt to print test cube, print blobs and infill instead August 17, 2010 07:55PM |
Re: Attempt to print test cube, print blobs and infill instead August 18, 2010 04:07AM |
Re: Attempt to print test cube, print blobs and infill instead August 18, 2010 11:13AM |
Re: Attempt to print test cube, print blobs and infill instead August 18, 2010 12:44PM |
Re: Attempt to print test cube, print blobs and infill instead August 18, 2010 02:39PM |
Re: Attempt to print test cube, print blobs and infill instead August 19, 2010 04:49AM |
Re: Attempt to print test cube, print blobs and infill instead August 19, 2010 07:40PM |
Re: Attempt to print test cube, print blobs and infill instead August 20, 2010 03:47AM |
Re: Attempt to print test cube, print blobs and infill instead August 22, 2010 12:52PM |
