Skeiniso isn't working for me.
Posted by jgilmore
November 16, 2010 10:32AM
When I process an STL, the skeiniso view comes up momentarily, and it look awesome.
When I try to pull it up manually on an existing gcode file, I get:
Skeiniso settings have been saved.
Extrusion settings have been saved.
Skeinforge profile settings have been saved.
Skeinforge settings have been saved.
The lower left corner of the skeiniso window is at 999999999.0, 999999999.0
The upper right corner of the skeiniso window is at -999999999.0, -999999999.0
Exception in Tkinter callback
Traceback (most recent call last):
File "/usr/lib/python2.5/lib-tk/Tkinter.py", line 1417, in __call__
return self.func(*args)
File "/home/jgilmore/reprap/t/fabmetheus_utilities/settings.py", line 1059, in execute
File "/home/jgilmore/reprap/t/skeinforge_application/skeinforge_plugins/analyze_plugins/skeiniso.py", line 365, in execute
File "/home/jgilmore/reprap/t/skeinforge_application/skeinforge_plugins/analyze_plugins/skeiniso.py", line 278, in getWindowAnalyzeFile
File "/home/jgilmore/reprap/t/skeinforge_application/skeinforge_plugins/analyze_plugins/skeiniso.py", line 286, in getWindowAnalyzeFileGivenText
File "/home/jgilmore/reprap/t/skeinforge_application/skeinforge_plugins/analyze_plugins/skeiniso.py", line 294, in getWindowGivenTextRepository
File "/home/jgilmore/reprap/t/skeinforge_application/skeinforge_plugins/analyze_plugins/skeiniso.py", line 680, in __init__
File "/home/jgilmore/reprap/t/skeinforge_application/skeinforge_plugins/analyze_plugins/analyze_utilities/tableau.py", line 230, in addMouseToolsBind
File "/home/jgilmore/reprap/t/skeinforge_application/skeinforge_plugins/analyze_plugins/analyze_utilities/tableau.py", line 207, in addLine
File "/home/jgilmore/reprap/t/skeinforge_application/skeinforge_plugins/analyze_plugins/skeiniso.py", line 766, in getColoredLines
IndexError: list index out of range
I don't know why it vanishes after displaying successfully when I'm processing a stl, but it doesn't produce an error message.
I'm using the latest beta: 35_reprap_python_beanshell.zip, dated 2010-11-06 05:14:02 CET
I'm building it with Baling Wire
Re: Skeiniso isn't working for me.
November 16, 2010 10:38AM
How about a link to the .gcode file that is giving you this problem.
Bob Morrison
Wörth am Rhein, Germany
"Luke, use the source!"
BLOG - PHOTOS - Thingiverse
November 16, 2010 03:30PM
Sure, here it is. Would have done that earlier but the 253K file size was intimidating. Zips up nice though.
open | download - bar-clamp.zip (40.9 KB)
November 17, 2010 02:38AM
With Skeiniso I get the same problem.
Skeinlayer works but there is something in the hole of your bar clamp layer #15 to #28!
I only ever use Skeinlayer.
Bob Morrison
November 17, 2010 10:12AM
Oh, I'd just been messing with support settings. So there's a little bit of extra plastic positioned oddly in this particular version. I was messing with skeinforge settings and regenerating the gcode to see what effect they all had, must have regenerated the gcode at least a dozen times.
And yes, skeinlayer works fine. skieniso very consistently does not.
November 17, 2010 10:45AM
jgilmore
That's why I don't use it! tongue sticking out smiley
Bob Morrison
November 17, 2010 07:27PM
But it's so pretty!
Or perhaps I should find a different gcode visualizer? There's no reason that my computer couldn't handle a nice 3D rotatable representation of at least this simple object.
I'd expect other g-code visualizers to be aimed at subtractive machining, I wonder how well they'd work with our stuff?
I'll download EMC2 and try that.
