Thanks for the suggestion. While it seems to have fixed another problem I was having, it still appears to be using the tower settings. I'm a bit confused though because "maximum tower height" is set to 5, yet it only prints two layers at each tower.
Prior to deleting the old settings, tower had been set to 2 layers. Is it possible that it is somehow pulling these settings from a location other than the settings folder that is in my user's home folder?
I need to do more testing to confirm if it is time/speed related or not , but for the moment my arduino has stopped restarting itself mid-build. When I wiped out the old settings folder, I started a new profile with my feed rates doubled from what I had been using. I finally managed to print a Skeinforge generated Gcode file all the way through for the first time.
Edit: Nope, both problems are still there.
Edited 1 time(s). Last edit at 12/12/2010 05:22PM by dazed.dnc.
