Re: Skeinforge 40 Changes to Dimension - Read this for problems with the new version of Skeinforge! March 13, 2011 08:03AM |
Re: Skeinforge 40 Changes to Dimension - Read this for problems with the new version of Skeinforge! March 13, 2011 01:15PM |
Re: Skeinforge 40 Changes to Dimension - Read this for problems with the new version of Skeinforge! March 16, 2011 10:07AM |
Re: Skeinforge 40 Changes to Dimension - Read this for problems with the new version of Skeinforge! March 16, 2011 11:05AM |
Re: Skeinforge 40 Changes to Dimension - Read this for problems with the new version of Skeinforge! March 16, 2011 12:35PM |
Re: Skeinforge 40 Changes to Dimension - Read this for problems with the new version of Skeinforge! March 16, 2011 12:51PM |
Re: Skeinforge 40 Changes to Dimension - Read this for problems with the new version of Skeinforge! March 16, 2011 01:01PM |
Re: Skeinforge 40 Changes to Dimension - Read this for problems with the new version of Skeinforge! March 16, 2011 01:29PM |
Re: Skeinforge 40 Changes to Dimension - Read this for problems with the new version of Skeinforge! March 16, 2011 01:42PM |
#define E0_STEPS_PER_MM 85.365 // NEMA 17 59/11 geared extruder 8mm diameter drive SF 40 defines this based on feedstock #define E1_STEPS_PER_MM 85.365 // NEMA 17 59/11 geared extruder 8mm diameter drive SF 40 defines this based on feedstock
Re: Skeinforge 40 Changes to Dimension - Read this for problems with the new version of Skeinforge! March 16, 2011 02:33PM |
Re: Skeinforge 40 Changes to Dimension - Read this for problems with the new version of Skeinforge! March 16, 2011 02:57PM |
Re: Skeinforge 40 Changes to Dimension - Read this for problems with the new version of Skeinforge! March 16, 2011 03:47PM |
Re: Skeinforge 40 Changes to Dimension - Read this for problems with the new version of Skeinforge! March 16, 2011 06:52PM |
Re: Skeinforge 40 Changes to Dimension - Read this for problems with the new version of Skeinforge! March 17, 2011 01:52AM |
Admin Registered: 14 years ago Posts: 1,469 |
Help improve the RepRap wiki!
Just click "Edit" in the top-right corner of the page and start typing. Anyone can edit the wiki! |
Re: Skeinforge 40 Changes to Dimension - Read this for problems with the new version of Skeinforge! March 17, 2011 05:25AM |
Re: Skeinforge 40 Changes to Dimension - Read this for problems with the new version of Skeinforge! March 17, 2011 06:18AM |
Re: Skeinforge 40 Changes to Dimension - Read this for problems with the new version of Skeinforge! March 17, 2011 07:33AM |
Re: Skeinforge 40 Changes to Dimension - Read this for problems with the new version of Skeinforge! March 17, 2011 11:19AM |
Re: Skeinforge 40 Changes to Dimension - Read this for problems with the new version of Skeinforge! March 17, 2011 11:54AM |
Re: Skeinforge 40 Changes to Dimension - Read this for problems with the new version of Skeinforge! March 17, 2011 12:19PM |
Re: Skeinforge 40 Changes to Dimension - Read this for problems with the new version of Skeinforge! March 17, 2011 04:25PM |
Re: Skeinforge 40 Changes to Dimension - Read this for problems with the new version of Skeinforge! March 17, 2011 10:54PM |
Re: Skeinforge 40 Changes to Dimension - Read this for problems with the new version of Skeinforge! March 18, 2011 01:38AM |
Re: Skeinforge 40 Changes to Dimension - Read this for problems with the new version of Skeinforge! March 18, 2011 01:44AM |
Re: Skeinforge 40 Changes to Dimension - Read this for problems with the new version of Skeinforge! March 18, 2011 06:14AM |
Re: Skeinforge 40 Changes to Dimension - Read this for problems with the new version of Skeinforge! March 18, 2011 08:56AM |
The tricky setting is the 'Filament Packing Density'. The default is 0.85, this is for ABS.
The default value is so low for ABS because ABS is relatively soft and with a pinch wheel extruder the teeth of the pinch dig in farther, so it sees a smaller effective diameter. With a hard plastic like PLA the teeth of the pinch wheel don't dig in as far, so it sees a larger effective diameter, so feeds faster, so for PLA the value should be around 0.97. This is with Wade's hobbed bolt. The effect is less significant with larger pinch wheels.
Overall, you'll have to find the optimal effective 'Filament Packing Density' by experiment.
Re: Skeinforge 40 Changes to Dimension - Read this for problems with the new version of Skeinforge! March 18, 2011 10:53AM |
Re: Skeinforge 40 Changes to Dimension - Read this for problems with the new version of Skeinforge! March 18, 2011 12:32PM |
Admin Registered: 16 years ago Posts: 7,871 |
Re: Skeinforge 40 Changes to Dimension - Read this for problems with the new version of Skeinforge! March 18, 2011 12:50PM |
