Re: Skeinforge 40 Changes to Dimension - Read this for problems with the new version of Skeinforge! March 18, 2011 01:40PM |
Admin Registered: 17 years ago Posts: 1,472 |
Re: Skeinforge 40 Changes to Dimension - Read this for problems with the new version of Skeinforge! March 19, 2011 10:53AM |
Re: Skeinforge 40 Changes to Dimension - Read this for problems with the new version of Skeinforge! March 19, 2011 03:03PM |
Re: Skeinforge 40 Changes to Dimension - Read this for problems with the new version of Skeinforge! March 20, 2011 10:07AM |
Re: Skeinforge 40 Changes to Dimension - Read this for problems with the new version of Skeinforge! March 20, 2011 12:02PM |
Re: Skeinforge 40 Changes to Dimension - Read this for problems with the new version of Skeinforge! March 20, 2011 02:19PM |
Re: Skeinforge 40 Changes to Dimension - Read this for problems with the new version of Skeinforge! March 21, 2011 06:11AM |
Re: Skeinforge 40 Changes to Dimension - Read this for problems with the new version of Skeinforge! March 21, 2011 07:50AM |
Admin Registered: 19 years ago Posts: 7,883 |
Re: Skeinforge 40 Changes to Dimension - Read this for problems with the new version of Skeinforge! March 21, 2011 08:11AM |
Re: Skeinforge 40 Changes to Dimension - Read this for problems with the new version of Skeinforge! March 21, 2011 09:29AM |
Re: Skeinforge 40 Changes to Dimension - Read this for problems with the new version of Skeinforge! March 21, 2011 09:42AM |
Re: Skeinforge 40 Changes to Dimension - Read this for problems with the new version of Skeinforge! March 21, 2011 06:39PM |
Re: Skeinforge 40 Changes to Dimension - Read this for problems with the new version of Skeinforge! March 23, 2011 05:45AM |
If I move manually the z axis it works fine - 50mm for 50mm - this means mechanics + electornics + firmware is ok. I looked at the gcode and it ends where it should end (ie box 20x20x20mm should end at 20mm height, and the gcode ends with 19.79 - so software is fine.|
Re: Skeinforge 40 Changes to Dimension - Read this for problems with the new version of Skeinforge! March 23, 2011 09:06AM |
Re: Skeinforge 40 Changes to Dimension - Read this for problems with the new version of Skeinforge! March 23, 2011 09:54AM |
Re: Skeinforge 40 Changes to Dimension - Read this for problems with the new version of Skeinforge! March 23, 2011 10:29AM |
Re: Skeinforge 40 Changes to Dimension - Read this for problems with the new version of Skeinforge! March 23, 2011 10:55AM |
Re: Skeinforge 40 Changes to Dimension - Read this for problems with the new version of Skeinforge! March 23, 2011 11:38AM |
Re: Skeinforge 40 Changes to Dimension - Read this for problems with the new version of Skeinforge! March 23, 2011 11:52AM |
As the temperature of the filament changes throughout the different stages, (Room temperature, different temperatures within the extruder, at the nozzle exit, on the part after extrusion) so changes its density >>volume while the mass would remain the same..
Now you have a filament that goes in at say 10g/mm3, it will have a molten density of maybe 9g/mm3 in the nozzle, but this will be back to 10 or 11g/mm3 at the extruder tip(narrow part), and suddenly go down to 9 again causing the die swell.
Re: Skeinforge 40 Changes to Dimension - Read this for problems with the new version of Skeinforge! March 23, 2011 02:13PM |
Re: Skeinforge 40 Changes to Dimension - Read this for problems with the new version of Skeinforge! March 23, 2011 02:38PM |
Re: Skeinforge 40 Changes to Dimension - Read this for problems with the new version of Skeinforge! March 23, 2011 03:59PM |
Re: Skeinforge 40 Changes to Dimension - Read this for problems with the new version of Skeinforge! March 23, 2011 04:19PM |
Re: Skeinforge 40 Changes to Dimension - Read this for problems with the new version of Skeinforge! March 23, 2011 05:12PM |
Re: Skeinforge 40 Changes to Dimension - Read this for problems with the new version of Skeinforge! March 23, 2011 08:37PM |
Re: Skeinforge 40 Changes to Dimension - Read this for problems with the new version of Skeinforge! March 24, 2011 03:20PM |
Re: Skeinforge 40 Changes to Dimension - Read this for problems with the new version of Skeinforge! March 27, 2011 01:06PM |
Re: Skeinforge 40 Changes to Dimension - Read this for problems with the new version of Skeinforge! March 27, 2011 11:06PM |
# return self.getExtrusionDistanceStringFromExtrusionDistance(scaledFlowRate / self.feedRateMinute * distance) return self.getExtrusionDistanceStringFromExtrusionDistance(self.flowScaleSixty / 60.0 * distance)
Re: Skeinforge 40 Changes to Dimension - Read this for problems with the new version of Skeinforge! March 29, 2011 08:10AM |
Re: Skeinforge 40 Changes to Dimension - Read this for problems with the new version of Skeinforge! March 29, 2011 08:12AM |
