Hi Guys,
I'm sure I need to install skeinforge in my Arch, but so far I'm not sure what package I need to install. Using pronterface + slic3r. I was trying find skeinforge_craft.py inmy system but looks like is not there.
My default path for this is:
slice command: python skeinforge/skeinforge_application/skeinforge_utilities/skeinforge_craft.py $s
Slicer options command: python skeinforge/skeinforge_application/skeinforge.py
My error output is:
Connecting...
Printer is now online.
Slicing /home/crystal/Downloads/BallsMk2.stl
Running python skeinforge/skeinforge_application/skeinforge_utilities/skeinforge_craft.py /home/crystal/Downloads/BallsMk2.stl --load /home/crystal/.Slic3r/print/01mm.20infill.ini --load /home/crystal/.Slic3r/printer/safe_settings_printer.ini --load /home/crystal/.Slic3r/filament/PLA_filament_200_60.ini
python: can't open file 'skeinforge/skeinforge_application/skeinforge_utilities/skeinforge_craft.py': [Errno 2] No such file or directory
Loading file: /home/crystal/Downloads/BallsMk2_export.gcode
Exception in thread Thread-15:
Traceback (most recent call last):
File "/usr/lib/python2.7/threading.py", line 801, in __bootstrap_inner
self.run()
File "/usr/lib/python2.7/threading.py", line 754, in run
self.__target(*self.__args, **self.__kwargs)
File "/usr/lib/python2.7/site-packages/printrun/pronterface.py", line 1411, in load_gcode_async_thread
gcode = gcode)
File "/usr/lib/python2.7/site-packages/printrun/pronsole.py", line 891, in load_gcode
self.fgcode.prepare(open(filename, "rU"),
IOError: [Errno 2] No such file or directory: u'/home/crystal/Downloads/BallsMk2_export.gcode'
any advise about how to get install this skeinforge.
Edited 1 time(s). Last edit at 06/05/2017 12:02PM by karcio.
