Bottom Feature March 22, 2011 04:06PM |
Re: Bottom Feature March 22, 2011 07:11PM |
Admin Registered: 15 years ago Posts: 1,470 |
(emphasis mine)Quote
Additional Height over Layer Thickness
Default is half.
The layers will start at the altitude plus the Additional Height over Layer Thickness times the layer thickness. The default value of half means that the bottom layer is at the height of the bottom slice, because each slice is made through the middle of each layer. Raft expects the layers to start at an additional half layer thickness. You should only change Additional Height over Layer Thickness if you are manipulating the skeinforge output with your own program which does not use the raft tool.
Altitude
Default is zero.
Defines the altitude of the bottom of the model. The bottom slice have a z of the altitude plus half the layer thickness.
Help improve the RepRap wiki!
Just click "Edit" in the top-right corner of the page and start typing. Anyone can edit the wiki! |
Re: Bottom Feature March 23, 2011 10:39AM |
Re: Bottom Feature March 23, 2011 01:52PM |
Re: Bottom Feature March 23, 2011 03:50PM |
Admin Registered: 17 years ago Posts: 7,879 |
Re: Bottom Feature March 23, 2011 04:23PM |
Re: Bottom Feature March 23, 2011 05:14PM |
Re: Bottom Feature March 23, 2011 07:18PM |
