I just printed a large gear for a Wades extruder using SF41 and the following settings. The gear came out really well although it is slightly raised on the underside which lifeted the edges off the bed while printing. It wasn't a problem as the middle had stuck really well
Skeinforge 41 settings
Profile type – Extrusion
Profile selection – No 4 (I have several I just kept cloning them so I could keep track of changes)
Search
Version – 11.04.26
Craft
Bottom
Activate Bottom –– Yes
Additional height over layer thickness (ratio) 0.7
Altitude (mm) 0.0
SVG viewer webbrowser
Carve
Add layer template to SVG – Yes
Extra decimal places (float) 2.0
Import coarseness (ratio) 1.0
Infill in direction of bridge – Yes
Layer thickness (mm) 0.4
-Layers-
Layers from (index) 0
Layers to (index) 912345678
Mesh type correct mesh – Yes
Perimeter width over thickness (ratio) 1.8
Chamber
Activate chamber – No
Clip
Activate clip – Yes
Clip over perimeter width (ratio) 0.5
Maximum connection distance over perimeter width (ratio) 10.0
Comb, Cool
Activate – No
Dimension
Activate dimension – Yes
Absolute extrusion distance – Yes
Extruder retraction speed (mm/s) 50.0
-Filament-
Filament diameter (mm) 2.8 (measured with digital callipers)
Filament packing density (ratio) 1.0
Retraction distance (mm) 2.0
Restart extra distance (mm) -0.5
Export
Activate export – Yes
Add export suffix – Yes
Gcode small – Yes
Fill
Activate fill – Yes
-Diaphragm-
Diaphragm period (layers) 100
Diaphragm thickness (layers) 0
-Extra shells-
Extra shells on alternating solid layer (layers) 2
Extra shells on base (layers) 1
Extra shells on sparse layer (layers) 1
-Grid-
Grid circle separation over perimeter width (ratio) 0.2
Grid extra overlap (ratio) 0.1
Grid junction separation band height (layers) 10
Grid junction separation over octagon radios at end (ratio) 0.0
Grid junction separation over octagon radios at middle (ratio) 0.0
-Infill-
Infill begin rotation (degrees) 45.0
Infill begin rotation repeat (layers) 1
Infill odd layer extra rotation (degrees) 90.0
Line – Yes
Infill perimeter overlap (ratio) 0.15
Infill solidity 1.0 (good for PLA)
Infill width over thickness (ratio) 1.7
Solid surface thickness (layers) 3
Fillet, Home, Hop, Inset, Jitter, Lash
Activate – No
Limit
Activate limit – Yes
Maximum initial feed rate (mm/s) 75.0
Maximum Z feed rate (mm/s) 3.0
Multiply
Activate multiply – Yes
-Centre-
Centre X (mm) 100
Centre Y (mm) 100
-Number of cells-
Number of columns (integer) 1
Number of rows (integer) 1
Separation over perimeter width (ratio) 15.0
Oozebane
Activate oozebane – No
Preface (can’t be turned off)
-Name of alteration files-
Name of end file – end code.gcode
Name of start file – start code.gcode
Set positioning to absolute – Yes
Set units to millimetres – Yes
Your start and end codes are kept in the Skeinforge alterations folder
Raft
Activate raft – Yes
Add raft, elevate nozzle, orbit – Yes
-Base-
Base feed rate multiplier (ratio) 1.0
Base flow rate multiplier (ratio) 1.0
Base infill density (ratio) 0.5
Base layer thickness over layer thickness 2.0
Base layers (integer) 0
Base nozzle lift over base layer thickness (ratio) 0.4
-Interface-
Interface feed rate multiplier (ratio) 1.0
Interface flow rate multiplier (ratio) 1.0
Interface infill density (ratio) 0.5
Interface layer thickness over layer thickness 1.0
Interface layers (integer) 0
Interface nozzle lift over interface layer thickness (ratio) 0.45
-Object first layer-
Object first layer feed rate infill multiplier (ratio) 0.4
Object first layer feed rate perimeter multiplier (ratio) 0.4
Object first layer flow rate infill multiplier (ratio) 0.4
Object first layer flow rate perimeter multiplier (ratio) 0.4
Operating nozzle lift over layer thickness (ratio) 0.5
-Raft size-
Raft additional margin over length (%) 1.0
Raft margin (mm) 3.0
-Support-
Activate support cross hatch – No
Scale
Activate scale – No
Skirt
Activate skirt – Yes
Convex – Yes
Gap over perimeter width (ratio) 10.0
Layers to (index) 1
(Initially I wasn’t getting a decent extrusion on the first layer of my prints so I added a skirt 10mm out from the print to solve this issue)
Speed
Activate speed – Yes
Add flow rate – Yes
-Bridge-
Bridge feed rate multiplier (ratio) 1.0
Bridge flow rate multiplier (ratio) 1.0
-Duty cycle-
Duty cycle at beginning (portion) 1.0
Duty cycle at ending (portion) 0.0
Feed rate (mm/s) 30.0
Flow rate setting (float) 30.0
Orbital feed rate over operating feed rate (ratio) 0.5
-Perimeter-
Perimeter feed rate over operating feed rate (ratio) 0.4
Perimeter flow rate over operating flow rate (ratio) 0.4
Travel feed rate (mm/s) 50.0
Splodge
Activate splodge – No
Stretch
Activate stretch – Yes
Cross limit distance over perimeter width (ratio) 5.0
Loop stretch over perimeter width (ratio) 0.11
Path stretch over perimeter width (ratio) 0.0
-Perimeter-
Perimeter inside stretch over perimeter width (ratio) 0.32
Perimeter outside stretch over perimeter width (ratio) 0.1
Stretch from distance over perimeter width (ratio) 2.0
Temperature, Tower, Unpause, Widen, Wipe
Activate – No
My start code is
G21; metric is good
G90; absolute positioning
G92 X0 Y0 Z0 E0; zero the extruded length axes
G92 E0
My end code is
G91
G1 F70
G1 Z7 F70; lifts nozzle 7mm from finished print surface
G1 F2300
G1 X-100 F2300
G90
M104 S0; turns off extruder
__________________________________________________________________________
Experimenting in 3D in New Zealand
