[SOLVED] To what extent does skeinforge control the temperature? July 06, 2011 12:53AM |
Re: To what extent does skeinforge control the temperature? July 06, 2011 01:41AM |
Re: To what extent does skeinforge control the temperature? July 06, 2011 07:17AM |
Re: To what extent does skeinforge control the temperature? July 08, 2011 12:05AM |
Re: To what extent does skeinforge control the temperature? July 08, 2011 01:28AM |
Re: To what extent does skeinforge control the temperature? July 08, 2011 01:59AM |
Re: To what extent does skeinforge control the temperature? July 10, 2011 11:12PM |
Re: To what extent does skeinforge control the temperature? July 10, 2011 11:15PM |
Re: To what extent does skeinforge control the temperature? July 11, 2011 02:08AM |
Re: To what extent does skeinforge control the temperature? July 11, 2011 07:15AM |
Re: To what extent does skeinforge control the temperature? July 11, 2011 07:30AM |
Re: To what extent does skeinforge control the temperature? July 11, 2011 01:56PM |
Re: To what extent does skeinforge control the temperature? July 11, 2011 02:28PM |
Re: To what extent does skeinforge control the temperature? July 11, 2011 06:33PM |
Admin Registered: 17 years ago Posts: 7,879 |
Re: To what extent does skeinforge control the temperature? July 11, 2011 07:08PM |
Re: To what extent does skeinforge control the temperature? July 11, 2011 08:10PM |
Re: To what extent does skeinforge control the temperature? July 12, 2011 12:18AM |
Re: To what extent does skeinforge control the temperature? July 12, 2011 12:52AM |
Re: To what extent does skeinforge control the temperature? July 12, 2011 04:26AM |
I used AL clad resistors powered from the mains.Quote
Nophead, how did you get your bed so hot?
Re: To what extent does skeinforge control the temperature? July 12, 2011 07:19AM |
Re: To what extent does skeinforge control the temperature? July 12, 2011 09:02PM |
Re: To what extent does skeinforge control the temperature? July 12, 2011 09:41PM |
unicoder
brnrd Wrote:
> Or your part is
> not making enough contact with the bed.
What do you mean by this? If it's as sticky as I here it shouldn't need much contact and like I said I had a solid first layer.
Re: To what extent does skeinforge control the temperature? July 12, 2011 10:21PM |
Re: To what extent does skeinforge control the temperature? July 12, 2011 11:36PM |
Re: To what extent does skeinforge control the temperature? July 13, 2011 02:59AM |
Re: To what extent does skeinforge control the temperature? July 13, 2011 03:05AM |
Re: To what extent does skeinforge control the temperature? July 13, 2011 11:33AM |
Re: To what extent does skeinforge control the temperature? July 13, 2011 11:51AM |
Re: To what extent does skeinforge control the temperature? July 13, 2011 03:40PM |
