Layer changes
Posted by NelsonRap
Layer changes
July 12, 2011 12:03AM
I seem to be still getting some ooze during layer changes. I already use retract and have it set to
Retraction distance 3
Restart extra distance 0
when I tried a negative number for the restart I ended up with gaps in some places so wonder if there is a setting to make the layer change faster?
Thanks,
I know more stupid questions but I'm learning
__________________________________________________________________________
Experimenting in 3D in New Zealand
Re: Layer changes
July 12, 2011 06:26AM
It's odd that a lot of people report this problem. How long does a layer change take? On my Mendel IIRC my z- axis moves at 5mm/s with acceleration over 256 steps. Moving say 0.4mm takes no time at all compared to an XY move from one corner of the bed to the opposite corner, so oozing on a z-lift isn't an issue.
How much ooze depends on how fast you retract as well as how far. I think it may also depend on how dry the PLA is.
Re: Layer changes
July 12, 2011 09:20AM
Are you using a bowden cable?
Re: Layer changes
July 12, 2011 10:13AM
I guess Nelson is using a Bowden cable. I have the same issue, but it's either strings or blobs with a Bowden, it seems.
I think retraction moves are generated independently in Skeinforge, so always happen without movement, which could be part of the issue - though maybe this is due to being able to specify the retraction speed, which needs to be set differently to any other feed rate? Another issue is that it does it on all hot end movements, even if it's only a move of a couple of mm. I saw someone wrote a python script to remove these, but it would be better if there was a little setting in SK - "Don't retract if move is less than..." kind of thing.
I'm using the 'lower left' setting for choosing where the next layer starts on layer changes, and I tend to get a ridge on the outside of the part in that position. But it's usually pretty neat, and easy to cut off if it's in the way.
Re: Layer changes
July 12, 2011 01:21PM
I was never able to get rid of the blobs when I was using a bowden at 40+mm/s. There is just too much elasticity in the filament, and not enough stepper speed to forward/reverse the feed fast enough.
Until somebody gets a nice mathematical model to accurately predict the nozzle response to the stepper, I think It will just have to be something you are forced to live with.
Or you can always switch to the predictable and accurate direct drive extruder.
Re: Layer changes
July 12, 2011 05:30PM
I'm actually running an Adrian's extruder on a Mendel.
I have extruder retraction speed set to 75mm/s. I might try and set it a bit higher for my next round of prints.
I have speed and flow set in speed to 30 each and I'm thinking I might lower these now too
Re: Layer changes
July 12, 2011 06:18PM
If you're on SF 40 or later, then 75 mm/s of feed is way too fast! I have it set to 15 mm/s. The electronics can't even pulse the steppers that fast.
Slowing down the feed rate from 30 mm/s won't really affect the ooze or blob between layer changes. Perhaps your nozzle is too hot.
Re: Layer changes
July 12, 2011 06:29PM
Maybe you're running the heater too hot, making the filament too liquid? I've reduced the temperature on mine a bit, from a reported 205 degrees (for PLA) down to 190. Unscientifically, it seems to ooze slightly less, and pushes through the extruder with about the same pressure. I wish I had one of those laser thermometers to know exactly what the temperature is. I'm building a Prusa, so should be going direct drive in time.
Re: Layer changes
July 12, 2011 07:21PM
Well I'm running at 175C which is flowing nicely
Re: Layer changes
If you mean the IR thermometers with laser guide, they're not good for measuring the nozzle temperature. The sensitive region is too big. The better way is to insert a thermocouple into the nozzle where the feed goes.
If you have a Huxley, why not build Adrian's extruder for 1.75 mm filaments. I thought that's small enough to fit on the carriage.
Re: Layer changes
July 12, 2011 08:52PM
Try retracting only .6mm at 20mm/s. I get small blobs if the retract distance is too high.
Since you had it set to 75mm/s my guess is you were skipping steps, too.
Re: Layer changes
July 12, 2011 10:15PM
Hmm not sure, I originally set it to retract at 50mm then was told on the Mendel forums that might be too slow.
So can anybody confirm or not whether a mendel with Adrian extruder running Gen6 can retract at those speeds.
Re: Layer changes
July 12, 2011 11:45PM
It depends on what version of Skeinforge you're using. For version 40 and later, that's too fast since the speed is based on the feed. If it's 39 and earlier, then it's too slow since the speed is based on the extruded filament. For an Adrian extruder 15 mm/s is a good value for version 40 and later and 540 mm/s (~36x) for earlier versions.
Re: Layer changes
July 12, 2011 11:57PM
Ah yep that makes sense I'm using SF41, will give it a go and see what happens
Re: Layer changes
July 13, 2011 04:26AM
I think the Gen6 board is speed limited by the firmware. I have one, and played around with speeds in repsnapper, but it topped out - sorry, can't remember off-hand at what speed. Higher speeds didn't seem to make it skip steps, just go at max speed. As retractions are carried out as single commands, is it likely to skip steps?
On mendel-parts, Camiel is experimenting with printing at 250mm/s with Gen6, so there should be some legs in it!
Thanks, I didn't realise they weren't very accurate. Obviously I've got a thermistor in my heater block, but I'm considering going the thermocouple route for subsequent hot ends.
My repstrap is a MrKim's 1X2, which is loosely based on the Huxley I suppose. However, it has the X axis smooth rods stacked vertically rather than horizontal, making is awkward to fit an extruder on top of the hot end without severely limiting the Z height. But it prints well enough for a repstrap. I'll go direct drive on the Prusa I'm building.
Re: Layer changes
July 13, 2011 11:12PM
Wow that is much better thanks, I didn't know that if it was too fast it would not work properly. The blobs are just about gone although I am getting a bit of stringing across big openings now so might up it a wee bit from 0.6 when I do the next prints.
Now all I have to work out is why my carriage stopped halfway across the last layer of a print, kept on extruding leaving a very large blob then dragging it all the way over once it thought the print was finished. I had to turn the power off and back on to get it working again which it has been all afternoon, maybe I looked at it funny or it didn't like my tone of voice
Re: Layer changes
July 14, 2011 12:04AM
> prints.
Awesome. The other thing to check is if there is any backlash in the extruder gears. Reducing that to practically zero also helps a lot.
Re: Layer changes
July 14, 2011 01:58AM
Is that what the lash tab is for? I haven't played with that before
Re: Layer changes
July 14, 2011 10:34AM
The lash tab is for x/y backlash. I don't think there is any way to compensate for extruder backlash. Best try to eliminate it mechanically with good gear/gear spacing.
