MemoryError when creating large parts G code
Posted by BogyX
September 07, 2011 06:33AM
Hello
I need to create a G code from a large STL (I combned couple of STLs to print it together). It takes a long time (I know, that is shood) but at the end I just getting that error and G code is not writen. I got picture of 3D path (but not 2D path by layers) and a Memory error as seen on attached picture.
Any ideas - I heawe no problems with small simple parts (wel at least not that kind of problem :-) ).
PC is 4GB Toshiba i3 with 64bit Win 7.
Regards
Bogdan
open | download - Skeinforhe - Memory Error.jpg (382.1 KB)
Re: MemoryError when creating large parts G code
September 07, 2011 07:38AM
Disable skeiniso and skeinlayer.
If you want to preview layers you should enable output penultimate gcode in export and open that file afterwards from skeinlayer.
Most of the time disabling skeiniso is sufficient but as you say that the skein takes long be safe.
Manufacturer of low tolerance Filaments PLA, ABS, ASA, PETG, TPU, PA, PVA,
[www.miafilament.com]
[github.com]
September 07, 2011 08:45AM
I'm trying that now - thank you, I will post replay, when Gcode is created.
Regards
Bogdan
September 08, 2011 04:14AM
It works.
Thank you.
Regards.
Bogdan
