Upgrade to 42, will need to redo all settings ?
Posted by DeuxVis
September 26, 2011 05:44AM
I'd like to upgrade to skeinforge 42 (from 41) but I'm not confident enough yet that I'll be able to remind all the settings changes I made.
Will the new version use the settings from the previous version or will I have to redo it from scratch ?
Thanks.
Re: Upgrade to 42, will need to redo all settings ?
September 26, 2011 11:04AM
It should be fine, except that the names of the start/end.gcode files have moved from Export to the new Bookend module - check that Bookend has the right names for your profile - and that the Max Z Feed Rate value has moved from Limit to Speed so also check that one.
You might want to give it a day or so before upgrading or use the nightly build instead as there have been a couple bugs found in 42. Enrique has been very quick on fixing these so I'm hopeful that 43 (or 42a or something) will be out soon.
September 26, 2011 11:17AM
Ok, I sure can wait a few day. Thanks.
September 28, 2011 10:36PM
Wait no more - SF43 is out and it's quite nice!
