SF41 Settings
September 28, 2011 10:45AM
I hope all forum members are well.
Please see below some SF41 settings for a RepRap Mendel on Windows 7 using an Adrians Geared Extruder, 0.4mm nozzle (producing extrudate a width of roughly 0.48mm), Repsnapper and PLA Plastic.
Thanks go to NelsonRap who initially posted some settings which got me started. I have tweaked some of these settings and managed to print some good quality calibration prints and a set of Mendel parts with these settings.
If any further details are needed, let me know.
Regards to all.
Craft
Bottom
Activate Bottom –– Yes
Additional height over layer thickness (ratio) 0.4
Altitude (mm) 0.0
SVG viewer webbrowser
Carve
Add layer template to SVG – Yes
Extra decimal places (float) 2.0
Import coarseness (ratio) 1.0
Infill in direction of bridge – Yes
Layer thickness (mm) 0.4
-Layers-
Layers from (index) 0
Layers to (index) 912345678
Mesh type correct mesh – Yes
Perimeter width over thickness (ratio) 1.25
Chamber
Activate chamber – No
Clip
Activate clip – Yes
Clip over perimeter width (ratio) 0.32
Maximum connection distance over perimeter width (ratio) 10.0
Comb, Cool
Activate – No
Dimension
Activate dimension – Yes
Absolute extrusion distance – Yes
Extruder retraction speed (mm/s) 16mm
-Filament-
Filament diameter (mm) 2.8 (measured with digital callipers)
Filament packing density (ratio) 1.0
Retraction distance (mm) 2.85
Restart extra distance (mm) 0.2
Export
Activate export – Yes
Add export suffix – Yes
Gcode small – Yes
Fill
Activate fill – Yes
-Diaphragm-
Diaphragm period (layers) 100
Diaphragm thickness (layers) 0
-Extra shells-
Extra shells on alternating solid layer (layers) 2
Extra shells on base (layers) 1
Extra shells on sparse layer (layers) 1
-Grid-
Grid circle separation over perimeter width (ratio) 0.2
Grid extra overlap (ratio) 0.1
Grid junction separation band height (layers) 10
Grid junction separation over octagon radios at end (ratio) 0.0
Grid junction separation over octagon radios at middle (ratio) 0.0
-Infill-
Infill begin rotation (degrees) 45.0
Infill begin rotation repeat (layers) 1
Infill odd layer extra rotation (degrees) 90.0
Line – Yes
Infill perimeter overlap (ratio) 0.15
Infill solidity 0.75
Infill width over thickness (ratio) 1.25
Solid surface thickness (layers) 3
Fillet, Home, Hop, Inset, Jitter, Lash
Activate – No
Limit
Activate limit – Yes
Maximum initial feed rate (mm/s) 65
Maximum Z feed rate (mm/s) 1.0
Multiply
Activate multiply – No
Oozebane
Activate oozebane – No
Preface (can’t be turned off)
-Name of alteration files-
Name of end file – end code.gcode
Name of start file – start code.gcode
Set positioning to absolute – Yes
Set units to millimetres – Yes
Raft
Activate raft – No
Skirt
Activate skirt – Yes
Convex – Yes
Gap over perimeter width (ratio) 3.0
Layers to (index) 1
Speed
Activate speed – Yes
Add flow rate – Yes
-Bridge-
Bridge feed rate multiplier (ratio) 1.0
Bridge flow rate multiplier (ratio) 1.0
-Duty cycle-
Duty cycle at beginning (portion) 1.0
Duty cycle at ending (portion) 0.0
Feed rate (mm/s) 44.0
Flow rate setting (float) 44.0
Orbital feed rate over operating feed rate (ratio) 0.5
-Perimeter-
Perimeter feed rate over operating feed rate (ratio) 0.5
Perimeter flow rate over operating flow rate (ratio) 0.5
Travel feed rate (mm/s) 44.0
Splodge
Activate splodge – No
Stretch
Activate stretch – Yes
Cross limit distance over perimeter width (ratio) 5.0
Loop stretch over perimeter width (ratio) 0.11
Path stretch over perimeter width (ratio) 0.0
-Perimeter-
Perimeter inside stretch over perimeter width (ratio) 0.32
Perimeter outside stretch over perimeter width (ratio) 0.1
Stretch from distance over perimeter width (ratio) 2.0
Temperature, Tower, Unpause, Widen, Wipe
Activate – No
open | download - Picture0012.jpg (55.5 KB)
Re: SF41 Settings
September 28, 2011 10:53AM
Temperature is not activated ? I had no idea that can work.
Re: SF41 Settings
September 28, 2011 01:53PM
Most of us do that in the preface (bookends in sf 42)
VDX
Re: SF41 Settings
September 28, 2011 02:53PM
... or use external temperature controllers ...
Viktor
Re: SF41 Settings
September 28, 2011 04:51PM
Or preheat in the host software..
Until somebody tells the machine otherwise (or resets it) setting the temperature sticks.
Re: SF41 Settings
September 28, 2011 05:19PM
The temperature is set in Repsnapper at 200C and my Start GCode has M104 S200 T0 at the beginning.
I may need to increase this slightly to maintain a nozzle temperature above 190C for multiple part prints. I've only printed 3-4 parts per print, when i did try to print 6 vertices at once i had extruder problems so need to look into this further to see if this was due to hardware or software.
Regards
Raj
Re: SF41 Settings
September 29, 2011 02:29AM
That's interesting, I'll give it a try (setting in preface seems good for not forgetting).
