Need help with skeinforge setup (techzone z skipping and pauses fixed) October 01, 2011 09:07AM |
Re: Need help with skeinforge setup October 01, 2011 01:57PM |
Re: Need help with skeinforge setup October 01, 2011 05:34PM |
Re: Need help with skeinforge setup October 02, 2011 06:42AM |
Admin Registered: 14 years ago Posts: 2,569 |
Re: Need help with skeinforge setup October 02, 2011 09:45AM |
Re: Need help with skeinforge setup October 03, 2011 06:34AM |
Re: Need help with skeinforge setup October 03, 2011 06:40AM |
Re: Need help with skeinforge setup October 03, 2011 05:15PM |
Re: Need help with skeinforge setup October 03, 2011 09:04PM |
Re: Need help with skeinforge setup (techzone z skipping and pauses fixed) October 05, 2011 03:48AM |
Re: Need help with skeinforge setup (techzone z skipping and pauses fixed) October 05, 2011 06:13AM |
// Set these to 1 to disable an axis when it's not being used, // and for the extruder. Usually only Z is disabled when not in // use. You will probably find that disabling the others (i.e. // powering down the steppers that drive them) when the ends of // movements are reached causes poor-quality builds. (Inertia // causes overshoot if the motors are not left powered up.) #define DISABLE_X 0 #define DISABLE_Y 0 #define DISABLE_Z 1 #define DISABLE_E 0
Re: Need help with skeinforge setup (techzone z skipping and pauses fixed) October 05, 2011 09:29AM |
Original Denis patch didn't work for me either on techzone monotronics. It generates G code like this:|
Re: Need help with skeinforge setup (techzone z skipping and pauses fixed) October 05, 2011 09:39AM |
Re: Need help with skeinforge setup (techzone z skipping and pauses fixed) October 06, 2011 12:06AM |
Re: Need help with skeinforge setup (techzone z skipping and pauses fixed) October 06, 2011 02:31AM |
sanguino.upload.protocol=avrisp
Re: Need help with skeinforge setup (techzone z skipping and pauses fixed) October 06, 2011 07:51AM |
Re: Need help with skeinforge setup (techzone z skipping and pauses fixed) October 06, 2011 08:46AM |
Re: Need help with skeinforge setup (techzone z skipping and pauses fixed) October 06, 2011 09:44AM |
Re: Need help with skeinforge setup (techzone z skipping and pauses fixed) October 07, 2011 12:42PM |
Re: Need help with skeinforge setup (techzone z skipping and pauses fixed) October 07, 2011 07:27PM |
Re: Need help with skeinforge setup (techzone z skipping and pauses fixed) October 07, 2011 10:42PM |
Re: Need help with skeinforge setup (techzone z skipping and pauses fixed) October 08, 2011 04:10AM |
Re: Need help with skeinforge setup (techzone z skipping and pauses fixed) October 08, 2011 08:11AM |
Re: Need help with skeinforge setup (techzone z skipping and pauses fixed) October 09, 2011 08:37AM |
Re: Need help with skeinforge setup (techzone z skipping and pauses fixed) October 09, 2011 08:46AM |
Re: Need help with skeinforge setup (techzone z skipping and pauses fixed) October 12, 2011 10:25PM |
Re: Need help with skeinforge setup (techzone z skipping and pauses fixed) October 13, 2011 03:19AM |
Admin Registered: 18 years ago Posts: 14,166 |
Re: Need help with skeinforge setup (techzone z skipping and pauses fixed) August 06, 2013 05:33AM |
