First the configuration:
- Classic Mendel Hardware
- Sanguinololu Electronics
- Techzone Opto-endstops
- Pronterface host software (the latest one, circular control interface)
- Slic3r slicing software, integrated with pronterface.
- Sprinter firmware
I believe that everything is wired up correctly. The endstops have their LED's glowing and they stop glowing if I block the opto sensor. I
do not have the pullup resistors enabled in the configuration file.
Here's the problem. I can jog all three of the axis and they move both directions correctly but, when I hit one of the home buttons, the axis just jerks back and forth where it is sitting. Also, blocking the endstops doesn't seem to have any effect. I can still jog the axis in both directions.
On a final note - I tried using an older version of Pronterface just to see if it was the version but exactly the same thing happened so I believe it is in the firmware..
Any suggestions, oh wise and witty forum members? (I need the wisdom more than the wit at the moment) :-)
