Re: Relative Extrusion CuraEngine June 26, 2014 03:01PM |
Re: Relative Extrusion CuraEngine June 26, 2014 07:30PM |
| FFF Settings Calculator | Gcode post processors | Geometric Object Deposition Tool Blog |
| Tantillus.org | Mini Printable Lathe | How NOT to install a Pololu driver |
Re: Relative Extrusion CuraEngine July 08, 2014 12:42PM |
Re: Relative Extrusion CuraEngine July 08, 2014 02:18PM |
hercek
It is a pity you did not get this merged. The argument about accumulating error due to use of relative coordinates is silly. There are 4 decimal places after the dot in the *.gcode files. This may lead to volume error of about 2.4e-4 mm³ per one E movement. But filament diameter typically varies at least in the range like 1.74 to 1.76 mm. This leads to error of about 5.5e-2 mm³ per one 1 mm of E movement. That is about 200 times more. We should always use only relative coordinates for E movement (and absolute only for X/Y/Z movement). No need for an option in GUI.
Re: Relative Extrusion CuraEngine January 20, 2015 02:22PM |
Re: Relative Extrusion CuraEngine January 20, 2015 06:41PM |
Re: Relative Extrusion CuraEngine January 21, 2015 03:00PM |
