Is there a way to automate editing of gcode files? March 29, 2016 05:10AM |
Re: Is there a way to automate editing of gcode files? March 29, 2016 03:12PM |
Re: Is there a way to automate editing of gcode files? March 29, 2016 04:19PM |
Re: Is there a way to automate editing of gcode files? March 29, 2016 05:18PM |
G0 X56.102 Y61.759 Z10.100
G0 X56.102 Y61.759 Z10.100 M567 P4 E1
#!/usr/bin/perl -i
use strict;
use warnings;
# Declare some local variables
my $maxZ = 100; # The height of the object being printed
# Ramp colour A from 100% down to 0 over the height of the object
# Ramp colour B from 0 to 75% over the height of the object
# When A+B < 1, colour C is used to "top up" to 1. This means that colour C starts appearing at 67mm height, and ramps up to 25% at the maxZ
my $startA = 1; # Proportion of colour A at the first layer
my $endA = 0; # Proportion of colour A at maxZ
my $startB = 0;
my $endB = 0.75;
# Go through the input file, line by line
while ( <> ) {
# Print the existing line to the output
print;
if (my $match = m/Z(\d+\.?\d*)/) {
# If the line contains a Z followed by a number, then there's a height change, so insert a colour change M567 command
# The number is extracted and stored in the Perl variable $1
# Calculate the colour values
# This is a simple linear interpolation so that colours A & B ramp from their start to end values from 0 to the height of the object ($maxZ)
my $colourA = $startA + ( $endA-$startA )*$1/$maxZ;
my $colourB = $startB + ( $endB-$startB )*$1/$maxZ;
my $totalColour = $colourA + $colourB ;
my $colourC = 0;
# Ensure that the total of the colours is always equal to 1
if ($totalColour >= 1) {
$colourA /= $totalColour;
$colourB /= $totalColour;
} else {
$colourC = 1 - ( $colourA + $colourB );
# Output the M567 line. Each colour proportion is output with 2 decimal places
printf "M567 P4 E%4.2f:%4.2f:%4.2f\n", $colourA, $colourB, $colourC;
Re: Is there a way to automate editing of gcode files? March 30, 2016 05:03AM |
Re: Is there a way to automate editing of gcode files? March 30, 2016 05:07PM |
Re: Is there a way to automate editing of gcode files? March 31, 2016 04:49AM |
+":"+'{0:.2f}'.format(FilC)+"\n") to the output file. The formatting ensures that the output is always 2 decimal places because I discovered that taking 0.1 off of a floating point number repeatedly results in a very long number of decimal places (I remember reading something about that but can't remember the reason why). It might not matter but the resultant gcode file looks horrible. Anyway, it then reduces FilA by 0.01 and increases FilB by 0.01. If FilA<0 then it sets it to 0 and sets FilB to 1.00. Then it sets the Iteration to 2. If the iteration is 2 then it carries on through reducing FilB and increasing FilC until FilB reaches 0 at which point it changes Iteration to 3. Then it reduces FilC and increases FilA. When FilC reaches 0 it changes the iteration back to 1. So basically it "fades" the filaments from 100% A and 0% B through to 0% A and 100% B, then 100% B and 0% C to 0% B and 100% C, then 100%C and 0%A to 0%C and 100%A and in theory after 300 layers, it will start again with 100%A and 0%B.|
Re: Is there a way to automate editing of gcode files? March 31, 2016 07:17PM |
python35 [script].py [data].gcodeReplace [script] by the script filename, replace [data] by the name of your sample gcode file. If you're on Windows, the installer installs Python 3.5.1 with the executable named "python", not "python35".
. Use the Preview button to see where it happens. Insert a space between the B and ) to prevent that.
#!/usr/bin/python
import sys
import re
import os
# Declare some variables
maxZ = 100 # The height of the object being printed
startA = 1 # Proportion of colour A at the first layer
endA = 0 # Proportion of colour A at maxZ
startB = 0
endB = 0.75
# Write metadata to a log file
log = open(sys.argv[1]+".log","w")
log.write(str(len(sys.argv)) + ' arguments.\n')
for v in sys.argv :
log.write(v + "\n")
for v in os.environ :
log.write(v + ": " + os.getenv(v) + "\n")
infile = open(sys.argv[1])
outfile = open(sys.argv[1]+".postproc","w")
# Read the input file
for line in infile :
# Print the existing line to the output, without adding another newline
outfile.write(line)
match = re.search(r"Z(\d+\.?\d*)", line)
if match :
# The number extracted is stored in match.group(1)
height = float(match.group(1))
# Calculate proportions of colours A & B based on their linear ramps
colourA = startA + ( endA-startA )*height/maxZ
colourB = startB + ( endB-startB )*height/maxZ
totalColour = colourA + colourB
colourC = 0
if totalColour >= 1 :
colourA /= totalColour
colourB /= totalColour
else :
colourC = 1 - ( colourA + colourB )
outfile.write("M567 P4 E{0:.2f}:{1:.2f}:{2:.2f}\n".format(colourA, colourB, colourC))
# Close the files so that the OS can do things with them
outfile.close()
infile.close()
# Delete the original input file
os.remove(sys.argv[1])
# Rename the output file to be what the input file was called
os.rename(sys.argv[1]+".postproc", sys.argv[1])
Re: Is there a way to automate editing of gcode files? April 01, 2016 07:04AM |
startfile = open("D:\RepRap\G Code Files Diamond hot end\Python test file.gcode",'r')
endfile = open("D:\RepRap\G Code Files Diamond hot end\Python output.txt", 'w')
FilA=1.00
FilB=0.00
FilC=0.00
Iteration =1
LayerChange="G1 Z"
numLines=sum(1 for line in (startfile))
startfile.seek(0) # make sure we start at the beginning of the file
# use the following to limit part of file?? Check the file length (number of lines, and set x to this at start
for x in range (0,numLines):
#for line in startfile:
# if I use the above, it misses every other line but for x in range works ok.
LineText=(startfile.readline())
# uncomment the following line with caution - it really slows things down.
# print (LineText)
endfile.write(LineText)
if LayerChange in LineText:
TextToWrite =("M567 P3 E"+'{0:.2f}'.format(FilA)+":"+'{0:.2f}'.format(Fil
endfile.write (TextToWrite)
print (TextToWrite)
if Iteration == 1:
FilA=FilA-0.01
FilB=FilB+0.01
FilC=0.00
if FilA<0:
FilA=0.00
FilB=1.00
Iteration =2
if Iteration==2:
FilA=0.00
FilB=FilB-0.01
FilC=FilC+0.01
if FilB<0:
FilB=0.00
FilC=1.00
Iteration=3
if Iteration==3:
FilC=FilC-0.01
FilA=FilA+0.01
FilB=0.00
if FilC<0:
FilC=0.00
FilA=1.00
Iteration =1
startfile.close()
endfile.close()
Re: Is there a way to automate editing of gcode files? April 01, 2016 07:07AM |
Re: Is there a way to automate editing of gcode files? April 01, 2016 03:56PM |
import os.path
endname = "D:\RepRap\G Code Files Diamond hot end\Python output.txt"
if os.path.isfile(endname) :
print("File " + endname + " already exists"
quit()
endfile = open(endname, 'w')
for LineText in startfile:
Re: Is there a way to automate editing of gcode files? April 01, 2016 05:23PM |
Anonymous User
Re: Is there a way to automate editing of gcode files? April 14, 2016 10:42PM |
Re: Is there a way to automate editing of gcode files? April 15, 2016 01:30PM |
Re: Is there a way to automate editing of gcode files? July 20, 2016 07:38PM |
