Re: Introducing KISSlicer January 26, 2014 10:06AM |
Re: Introducing KISSlicer January 26, 2014 12:31PM |
| FFF Settings Calculator | Gcode post processors | Geometric Object Deposition Tool Blog |
| Tantillus.org | Mini Printable Lathe | How NOT to install a Pololu driver |
Re: Introducing KISSlicer January 29, 2014 11:25AM |
Re: Introducing KISSlicer January 29, 2014 01:48PM |
Re: Introducing KISSlicer January 31, 2014 03:55PM |
Re: Introducing KISSlicer January 31, 2014 05:34PM |
mihai
Sublime,
is there a post processor that adds brim to the gcode generated by kisslicer ?
thanks,
mihai
Re: Introducing KISSlicer February 04, 2014 09:59AM |
Re: Introducing KISSlicer February 04, 2014 11:59AM |
Sam123
Sublime,
Do you the profile settings for the BFB-3000 printer? Axon is not making the object solid and the printer quality isn't good. So, I tried KISSlicer but my printer (BFB3000) stops after it starts running the fans.
Printer :BFB3000 single head
Firmware: V4.2.2
Filament: PLA 3mm
Software: KISSlicer64
Thanks
Sam
Re: Introducing KISSlicer February 05, 2014 10:24AM |
Re: Introducing KISSlicer February 05, 2014 12:12PM |
Re: Introducing KISSlicer February 12, 2014 02:37PM |
Re: Introducing KISSlicer February 12, 2014 02:41PM |
Re: Introducing KISSlicer March 29, 2014 07:54PM |
Re: Introducing KISSlicer March 29, 2014 10:43PM |
Re: Introducing KISSlicer March 30, 2014 03:34PM |
Sublime
It is most likely the firmware selection is set to relative E in Kisslicer and your actual firmware is set to absolute E. So either add M84 to the start code in Kisslicer to tell the firmware to be in relative or change Kisslicer to absolute E to match the firmware.
Re: Introducing KISSlicer March 30, 2014 05:19PM |
bilsch
Looking at the gcode output from kisslicer, I don't see M82 or M83. Comparing the start of the output from slic3r I see M82 so that is very likely the problem thanks!
M82 ; use absolute distances for extrusion
Sublime
It is most likely the firmware selection is set to relative E in Kisslicer and your actual firmware is set to absolute E. So either add M83 to the start code in Kisslicer to tell the firmware to be in relative or change Kisslicer to absolute E to match the firmware.
Re: Introducing KISSlicer June 21, 2014 09:51AM |
Admin Registered: 13 years ago Posts: 3,096 |
Re: Introducing KISSlicer September 27, 2014 12:00AM |
Re: Introducing KISSlicer November 29, 2016 05:29PM |
Re: Introducing KISSlicer December 18, 2016 05:55AM |
Re: Introducing KISSlicer September 24, 2017 08:49AM |
Re: Introducing KISSlicer October 25, 2017 07:37AM |
Re: Introducing KISSlicer October 25, 2017 08:35AM |
Re: Introducing KISSlicer December 12, 2018 10:37AM |
Re: Introducing KISSlicer December 12, 2018 01:31PM |
Re: Multi coloured prints September 09, 2021 03:38PM |
