Sanguinololu LCD?
Posted by plainnash
Sanguinololu LCD?
December 25, 2011 05:30PM
Hi all,
Does anyone have any experience with wiring up an LCD to the Sanguinololu? I've searched around a bit but I can't find anything specific to this board.
Also, is Marlin the best firmware to use to support it?
Thanks for any help you can give,
plainnash
Re: Sanguinololu LCD?
January 13, 2012 10:43AM
I am looking into doing this as I would like to have it all stand alone with SD printing. Wiring up the LCD isn't an issue, but there doesn't seem to be enough pins for the LCD, SD and rotary switch. If I make any progress I will post up on here smiling smiley
January 13, 2012 10:07PM
you may be interested in this guy, serial lcd kit i am trying to get him to work with the ramps board, it is just a arduino with a lcd attached and the firmware to send it to the screen, i hope to have mine running on my new mendel when i get it up and running.
February 06, 2012 06:17PM
I'm using this serial/I2C 16x2 LCD on my Melzi board (connected by two pin I2C):
[www.ebay.com]
It works good after som modification of the Marlin firmware
(The RepRapPro_Huxley branch of Marlin on my github, Malx122 )
But it also exist solution for bigger displays and keypads that can be attached by I2C. (Will probably require even more modifications)
February 06, 2012 06:21PM
thats cheaper than the one i found, but it lacks the extra I/O pins, i am still trying to figure out what to change in my firmware
March 12, 2012 02:48PM
Which board/chip are you using? as I can't manage to compile your version of the firmware and fit it on an ATmega644p
Moo
March 25, 2012 05:20PM
I try to get a I2C 20x4 LCD working, but I'm still struggeling with the firmware...
[www.ebay.com]
Did someone succeed with serial LCD`S yet?
March 25, 2012 05:22PM
no i am still trying but coding is not my strong point. i work better with hardware. kinda sucks for me, but eh i do and learn what i can
Moo
March 25, 2012 05:40PM
Sorry,
I had deleted the rest of the text sad smiley
Did someone succeed with serial 20x4 Displays yet? The files on github seem only to work with the 16x2?
I gave it a try with both types, but the 20x4 fails sad smiley
Or has done someone already a "complete panel mod" with the marlin firmware?
Pin assignments / reccomended wiring for:
-SDSL
- Serial (20x4) LCD
- rotary-push encoder
March 25, 2012 05:47PM
The board looks really cool.
Take a look at Revars' LCD/Keyboard for Gen3 electronics.
His firmware source code is available on github.
Edited 1 time(s). Last edit at 03/25/2012 05:47PM by rhmorrison.
Bob Morrison
Wörth am Rhein, Germany
"Luke, use the source!"
BLOG - PHOTOS - Thingiverse
Moo
March 25, 2012 07:05PM
Hi Bob,
thank you for the link. That guy uses a 20x4 serial LCD smiling smiley
I'm wondering if a part of the code can be adapted to the marlin firmware...???
@dissidence maybe this link is helpful for the code: [forum.modtronix.com]
March 26, 2012 03:19AM
I don't know but I am about to attach exactly these modtronix LCD/Keyboard to my Mendel with Gen3 electronics.
I want to try using his modified Makerbot firmware as it is the least amount of work, but if I can't get it to work I may have to try integrating his source into a different firmware. At the moment I am using the old FiveD 201008.
Bob Morrison
