[done] SL 1.3 pauses or disconnects mid-print January 03, 2012 08:52AM |
Exception in thread Thread-8667: Traceback (most recent call last): File "/usr/lib/python2.7/threading.py", line 552, in __bootstrap_inner self.run() File "/usr/lib/python2.7/threading.py", line 505, in run self.__target(*self.__args, **self.__kwargs) File "/cdrom/rep/kliment-Printrun-6a63009/printcore.py", line 82, in _listen line=self.printer.readline() File "/usr/lib/python2.7/dist-packages/serial/serialposix.py", line 456, in read raise SerialException('device reports readiness to read but returned no data (device disconnected?)') SerialException: device reports readiness to read but returned no data (device disconnected?)
Re: SL 1.3 pauses or disconnects mid-print January 03, 2012 09:41AM |
Admin Registered: 12 years ago Posts: 2,569 |
Re: SL 1.3 pauses or disconnects mid-print January 03, 2012 10:05AM |
Re: SL 1.3 pauses or disconnects mid-print January 03, 2012 11:31AM |
Re: SL 1.3 pauses or disconnects mid-print January 03, 2012 12:07PM |
Re: SL 1.3 pauses or disconnects mid-print January 03, 2012 12:22PM |
Re: SL 1.3 pauses or disconnects mid-print January 04, 2012 05:58AM |
Re: SL 1.3 pauses or disconnects mid-print January 06, 2012 10:52PM |
Re: SL 1.3 pauses or disconnects mid-print January 09, 2012 12:51PM |
Re: SL 1.3 pauses or disconnects mid-print January 09, 2012 06:54PM |
Re: SL 1.3 pauses or disconnects mid-print January 09, 2012 09:15PM |
Re: SL 1.3 pauses or disconnects mid-print January 09, 2012 09:50PM |
Re: SL 1.3 pauses or disconnects mid-print January 26, 2012 03:16PM |
Re: SL 1.3 pauses or disconnects mid-print December 28, 2012 06:57PM |
Re: SL 1.3 pauses or disconnects mid-print January 07, 2013 12:59PM |
Re: [done] SL 1.3 pauses or disconnects mid-print February 11, 2014 02:30PM |
Ext Crystal :Frequency 8.0- MHz Start-up time 16K CK + 65ms Boot reset vector Enabled Boot Flash section size=512 words Boot start address=$FE00 Preserve EEPROM memory through Chip Erase cycle Serial program downloading (SPI) enabled Brown-out detection disabled
Re: SL 1.3 pauses or disconnects mid-print October 15, 2014 11:32PM |
Jean-Baptiste
"One more thing" to my previous post : I check the "Use Ping-Pong Communication (send only after ok)" parameter (set XON/XOFF) in the "Connection" tab of the "Printer setting" DialogBox, to avoid the faintest USB problem (Thank's Pierre from Gi-Nova Grenoble).
