1.3a circuit diagram?
January 13, 2012 10:19AM
I am probably being blind here but anyone know where I can find the circuit diagram for V1.3a? I want to put on Marlin and have the LCD, SD and Control panel and need one more pin then is available on the expansion pins. I am not sure about pin35 (A5 or D26). Unless I can get away without having the SD Card Detect?
Re: 1.3a circuit diagram?
January 13, 2012 10:46AM
Oops found it eagle schematic now, really do need to get glasses!! eye rolling smiley
January 15, 2012 09:58AM
Hi Smartroad,
Would you be kind enough to take a look at my sanguinlolou wiring of the Y-axis and let me know if my wiring is correct. See attachment
I would be very greatful.
Edited 1 time(s). Last edit at 01/15/2012 09:59AM by Dobert.
open | download - Sanguinololu with Y-axis wiring.pdf (155.7 KB)
January 15, 2012 10:01AM
My one is wired Green Black Red Blue with green nearest to the mosfets
January 17, 2012 02:55PM
I've been wanting to add LCD and a keypad for a while now. Could you please share your progress and discoveries here?
January 17, 2012 05:23PM
Hi TheCase,
Unless someone is able to come up with a serial interface so that another microcontroller could be used as the user interface, there aren't enough pins on the Sanguinololu to run the SD, LCD and selector switch. I am now moving over to RAMPS as that has more then enough pins in order to allow the use of all of them.
I was hoping to use my Sangi but it just doesn't seem possible sad smiley
