need help setting current limit (sanguinololu + pololus A4988
Posted by scanboy
February 07, 2012 10:25AM
Hello,
I've just finished soldering the electronics, now I need to setup the current limit pot on the A4988, I'm wondering can I plug the A4988 onto the sanguinololu 1.3a and set it up that way? If so, where can I measure the current and do I need to plug in both ATX power and usb?
I went to the wiki and seems like I need to make some connections on a breadboard (which I don't have) or connect up manually, which could be messy.
I need a safe way to do this since my motor current spec is a bit lower than normal (0.8a 6v).
Thanks in advance.
Re: need help setting current limit (sanguinololu + pololus A4988
February 08, 2012 11:31AM
bump
February 08, 2012 02:34PM
Set VREF to 0.32V on a genuine Pololu or 1.28V on a Stepstick. That gives a current of 0.8A. If the motor gets too hot reduce it.
You can measure VREF on the test point or on the wiper of the potentiometer.
Edited 1 time(s). Last edit at 02/08/2012 02:38PM by nophead.
March 05, 2012 09:55AM
> [lh4.googleusercontent.com]
> 5FdyLquI/AAAAAAAAF2U/Qm9xijmsHEI/s576/pololu.jpg
Thanks. I've made it work, all motors are turning fine, but some are turning in the opposite direction than what I expected, do I just swap the +/- wires?
March 05, 2012 12:51PM
Yes either put the motor plug on backwards or swap the first two wires.
March 06, 2012 02:21PM
Thanks a lot, but I still have one more question. I'm very close to doing my first print, while I was testing the extruder motor, I was wondering how does sprinter know how fast to extrude if I use 3mm filament vs. 1.75mm ones. I thought there would be a define in the configuration.h, but could not find anything related to the filament thickness, so how do I tell it what's the correct extrudsion rate is?
March 07, 2012 08:57AM
The firmware doesn't need to know the diameter because it extrudes by length. The slicer has to know the diameter to calculate the length for the E codes.
March 07, 2012 01:47PM
thanks so much, just downloaded slicer.
I connected A4988 to Stepper Motor: Unipolar/Bipolar, 200 Steps/Rev, 42x48mm, 4V, 1200mA
Vmm= 8.7V, Vdd = 6V. However my stepper motor refuses to move.
Any idea what is wrong.
