Resonator 16.00MHZ vs Crystals 16MHz
March 06, 2012 10:12PM
Hey everyone,
I am assembling my sanguinololu board v1.3. for what ever reason I must have not ordered the 16mhz resonator. I do how ever have 16mhz crystals. Is it possible for me to use my crystal?
[ca.mouser.com]
It fits in fine under the DIP socket. Going to be using the 1284P
Thanks!
Edited 1 time(s). Last edit at 03/06/2012 10:19PM by raymond3080.
Re: Resonator 16.00MHZ vs Crystals 16MHz
March 07, 2012 11:19AM
Yes it is ok to use crystals but you need to place bypass caps appropriate for the crystal to ground. Something between 18pf to 22 pf for most applications. The resonators has them already built in the case. Just so you know picking the wrong value of caps can mess up your uController timing.
March 07, 2012 12:01PM
Alright I have some .22pf 50v ceramic caps in my parts bin. What would be the best way to add them into the circuit?
March 08, 2012 02:34AM
I just flipped the crystal on to the back and put two 0402 .22pf caps on there...hopefully it works!
March 08, 2012 11:01AM
its 22pf not .22pf as you wrote. You mean 22pf right?
Connect each cap to each leg going to ground.
June 25, 2013 10:34AM
I bought a resonator with 16MHz and 15pF (bought wrong) can I use those resonator to my sanguinololu1.3a with Atmega1284p with some modification in firmware or Arduino compilation ?
June 25, 2013 09:30PM
Your resonator should work fine. Look at the atmega1284P datasheet page 32/33 for more info.
You don't need to make any modification to your Sanguino nor the firmware.
Edited 4 time(s). Last edit at 06/25/2013 09:37PM by lajos.
June 26, 2013 10:11AM
Thanks Lajos
Its working good now spinning smiley sticking its tongue out
