Thanks. The USBTiny seem to connect correctly. The power light on the Sanguinolulu came on, the green power light and busy light came on when loading the bootloader for the USB tiny but it fails to load the bootloader. I tried Arduino 018 and Arduino V1 with the Sanguino extension... I have the Atmega 644p
This is the message I get:
Error while loading bootloader.
avrdude: initialization failed, rc=-1
Double check connections and try again, or use -F to override
this check.
Any suggestions?
Edit: Do I need to remap the pins for the ribbon cable that came with the USBTiny? as mentioned in here? [
forums.reprap.org]
Edit2: I figured it out. I used arduino 18 with the respective sanguino extension. I plugged the 6 pin cord in with the red cord on the left. So it seemed like it was upside down. Not sure why I couldn't get it to work before.
Edited 3 time(s). Last edit at 04/08/2012 11:52PM by jininjin.
