So it looks like I really beat up my Sanguinolou 1.3a. Let me explain what happpened:
1. I hooked up my PC power supply for the first time. I blew out the 100uF capacitor on one of the motor control circuits...I had put it in backwards, my fault entirely. It blew out the 7805 as well.
2. No worries, I have plenty of 7805s and caps to replace them.
3. After replacing, I fired up with only one steppper driver and one stepper attached...the driver went up in smoke, the 7805 was hot to thethe touch.
4. At this point, I wanted to make sure I didn't fry the FTDI or the 644p...sure enough, over just USB I can't connect to the board, though its serial port is visable.
...now it looks like I need a new stepper driver and an Atmega, but with both of those, I'm not sure the 7805 circuit is working properly. I'm taking about 11.6v out of the ATX power supply and getting 4.9v out of the 7805...not sure if this slightly lower voltage is an issue.
Long story short, I messed it up pretty good and I am unsure of how to fix it. Any advice is welcomed...I'm close to just getting ramps as I just want the bastard to work finally!
Thanks!
