The problem: When turning on the extruder heater, and measuring voltages directly at the out-PINs of my sanguinololu, the extruder heater voltage reads 12.08V, but the bed heater reads a puny 6 to 9 millivolts and oscillates between those 2 values. Consequence: Extruder heats fine, bed doesn't.
I'm using a ATX1 260W PSU without dummy load yet.
I was thinking if it were the dummy load problem, the extruder heater should have a faulty voltage as well, but since it's working fine, I'm wondering what it could be.
I just installed my first heatbed, so it is also kinda unlikely that I have already blown the MOSFET....
Also: Resistance on both extruder heater and bed heater "+ to ground" lines (measured at the boards pins) are roughly the same at ~1kOhm, so I guess I also haven't shorted the pins while soldering.
Any help on that matter would be greatly appreciated
Edited 1 time(s). Last edit at 06/30/2012 12:13PM by Gara.
