Sanguinololu 1.3 Heating issue
Posted by artiface
November 06, 2012 08:09PM
My printer seems to be working, except once the heater gets hot - 230C for ABS - after about 5 minutes it suddenly starts dropping temperature, and will completely quit heating... the temp will drop far enough the plastic will not melt and will jam, etc..
Any idea's how to troubleshoot this?
Re: Sanguinololu 1.3 Heating issue
November 07, 2012 01:23AM
Hello Artiface,
I had the issue myself, maybe your situation is similar;
When my hot-end heated up above a certain temp, the soldering joint of the heater wire would let go (cold joint)
The wire would bend over the heat and no contact would be made.
After cooling down, the heater worked again, up until a certain treshold. It took me ages to find out!
Alternatively, check if the max heat setting in the firmware isn't around 230C
June 05, 2013 04:15PM
Did you find a solution to the overheating... if so you should leave an update on the thread you opened... yes ?
It may help others with similar problems
June 10, 2013 07:34PM
If the MOSFET is overheating, you can replace it with one that has lower Rds On. The IRLB8743PBF from digikey can even drive a pcb heat bed without heat sink.
Edited 2 time(s). Last edit at 06/10/2013 07:35PM by lajos.
