Bipolar motors are funny like that. Once you have identified the correct pairs, there are 8 possible ways of connecting the pairs. 4 of those go clockwise, the other 4 go counter-clockwise.
The actual color order used can therefore seem somewhat arbitrary. (Of course, "clockwise" is ambiguous, depending on which face of the motor you look at).
But, when you have established what color sequence is "clockwise" on your system, you can use that pattern to set the rest of the motors. If a motor goes the wrong way, it is easy to reverse by swapping one of the pairs, or reversing the whole connector by 180 deg if the connector is unpolarised.
