best practise for wiring heat bed via sevenswitch April 25, 2013 04:37PM |
Re: best practise for wiring heat bed via sevenswitch April 26, 2013 07:36AM |
However, I was wondering if there was a less intrusive solution, like using another pin somewhere on the board which is accessible and can be enabled in the firmware accordingly.
Generation 7 Electronics | Teacup Firmware | RepRap DIY |
Re: best practise for wiring heat bed via sevenswitch April 28, 2013 05:14PM |
Re: best practise for wiring heat bed via sevenswitch April 30, 2013 07:20AM |
Re: best practise for wiring heat bed via sevenswitch May 25, 2013 02:36AM |
Re: best practise for wiring heat bed via sevenswitch November 13, 2014 04:04AM |
Re: best practise for wiring heat bed via sevenswitch November 13, 2014 01:57PM |
Re: best practise for wiring heat bed via sevenswitch November 17, 2014 05:20PM |
prashantdshinde
@ Stemer114... how do you control the temparature using slicer/extruder software??
I am using RAMPS1.4, built a seven switch but I am not sure from where to take the +12v supply..... from RAMPS D8 or ext PSU?
