Using L297/L298 with Sanguino
August 16, 2013 05:02PM
I have burnt like 8 Polulu/Stepsticks. Those are costly and have long waiting time. So I was trying to run it with L297/L298.
The only problem is Polulu/Stepstick the DIR signal is on high, while on L297 it is on a low pulse. Is there a way to change the signal, in the Configuration.h? I'm using Splinter
Re: Using L297/L298 with Sanguino
August 17, 2013 07:20AM
Look for Generation 2 Electronics. Boards like the Stepper Driver 1.2 work just fine as a Pololu replacement. No microstepping, of course.
Also, DIR isn't a pulse, but a continuous signal. Can be inverted in about all firmwares.
August 19, 2013 05:05AM
Oops, I meant the step signal not the direction
August 19, 2013 03:56PM
Solved that. Used a 7404 invertor IC.
Just explaining in case anyone else tries it out.
First I had issues even using 7404 as the L297/8 circuit & Sanguino weren't linked. I was using a separate power source for Sanguino and another for the L297/8. Hence, so there was no absolute ground for the 7404, and hence it wasn't always high. When I used the same source, it worked like a charm.
August 20, 2013 07:30AM
Impressive how quite some people prefer to add costly hardware instead of changing a line of software code or two. Glad you got it working.
August 21, 2013 04:23AM
I couldn't find any setting in configuration.h file. So I went through the software. There are lot of places where they write output to the step pins. If I miss out couple of places or add new bugs, it would be a nightmare to find out what is wrong, when in the first hand I don't know fore sure that the my L297/8 circuit works properly. (I had built my own circuit, didnt buy a pre-tested board)
7404 is dirt cheap and I already had 1 lying unused. So it was a better solution, for now.
If anyone can point me to a setting in configuration.h file that would be the best solution.
August 22, 2013 04:30AM
Use a decent firmware, then. Teacup uses macros (in pinio.h) for such things for cases exactly like yours.
February 05, 2014 11:47PM
hey Traumflug !!
nice work man smiling smiley
can you share the firmware of reprap while using stepper driver 1.2
thanks
