Connecting Problems Prusa i3 with Sanguinololu
Posted by Mechanic
September 01, 2013 09:56AM
Hi All,
I am new on the 3D Printer scene and have the following problems, (until now, that is...:-) )+
building a Prusa i3 with Sanguinololu with Cura I can not find the Sanguinololu board listed in Arduino. I think that's why I cannot connect my printer to my laptop. I know that Sanguino software should be installed onto Arduino, but I cannot fix it.
The machine is mechanically OK., the Sanguinololu board is soldered and seems OK.
When I connect to my laptop, (com6) it is detected, the led is on and the USB sound is also there, so it connects,
But, when in Arduino, going through the set-up mode, the program tries to connect, "connecting", but after a few second there is this message:
"Machine State: Closed."
When I press the reset button on the Sanguinololu board, the stepper motors are rattling a few seconds, so there is something going on.
That is how it is at the moment, who can help me out there???
How can I get my computer and Cura to recognise my printer and what am I doing wrong?
As I am more a mechanic than a computer specialist, plaese keep it simple and step by step.
Thanks.
Peter J.
Re: Connecting Problems Prusa i3 with Sanguinololu
September 01, 2013 11:14PM
You won't find the board listed in the Aurduino IDE as the board listings are for the microprocessor used. Figure out which processor is on your board (IIRC many use an ATmega 1284) and use a setting in the board section that uses the same processor. There should also be something in the Wiki so a search there would be a good idea.
September 02, 2013 06:36AM
Thank you for the info, I will try it and keep you informed. Greetz. Peter J.
September 03, 2013 03:30AM
The above is correct, you need to select 644p or 1284p in the Arduino IDE
Sadly though they also aren't in the standard IDE, You download them from [code.google.com]
Also use Arduino 1.0.4 newer versions aren’t support (yet)
September 03, 2013 07:59AM
To Vegasloki and Dust,
thanks for your info, now the machine runs and I am going to learn.
September 05, 2013 05:23PM
Hi I am also a newbi my problem is that altough I can connect with ardurino and upload sprinter firmware I cannot get pronterface to connect, the screen shows the word connecting and hangs there although if I remove the usb cable pronterface goes balistic with error messages too fast to read.
The port is comport 8 and I have tried all baurd rates from 9600 up to the maximum my configoration.h is set for 115200.
please help I am going crazy on google with no results.
