It's my Third Motherboard and, I just want my printer to move.... Please Help March 03, 2014 09:57PM |
Re: It's my Third Motherboard and, I just want my printer to move.... Please Help March 03, 2014 11:02PM |
Re: It's my Third Motherboard and, I just want my printer to move.... Please Help March 04, 2014 11:55AM |
Dust
2) avrdude: stk500v2_ReceiveMessage(): timeout" is a communications error so the code compiled fine.
Two common causes, presuming there is a working boot loader on the chip.
1) you have left off the auto reset jumper, this needs to be on to allow the computer to reset the board to getting it into upload mode.
2) you are attempting to upload at the wrong baud rate, this is defined in your boards.txt file. and could be 38400 of 57600 depending on what boot loader they used.
Dust
3) you havent mentioned what version of arduino your using... or from where you got the gen7 or Sanguino file. some of these are know to be broken combinations
It looks like your gen 7 definitions are fine, and you should use those.
If your auto reset jumper is in place try the following.
Im going to presume you have [reprap.org]
Re: It's my Third Motherboard and, I just want my printer to move.... Please Help March 04, 2014 06:01PM |
Re: It's my Third Motherboard and, I just want my printer to move.... Please Help March 06, 2014 03:10AM |
Re: It's my Third Motherboard and, I just want my printer to move.... Please Help March 06, 2014 04:40PM |
Re: It's my Third Motherboard and, I just want my printer to move.... Please Help March 06, 2014 05:06PM |
Re: It's my Third Motherboard and, I just want my printer to move.... Please Help March 06, 2014 05:29PM |
Re: It's my Third Motherboard and, I just want my printer to move.... Please Help March 10, 2014 10:09PM |
Emadine
I just try to download the arduino n not problem1copy
to download win [arduino.googlecode.com]
to download mac [arduino.googlecode.com]
down loan Marlin from here [github.com]
it may not help, but this is what i do : unzip the marlin folder to arduino folder
1. copy the Sanguino folder from marlin add-on to arduino/hardware
2. copy and replace Marlin / ArduinoAddons / Arduino_0.xx / hardware / tools / avr / etc to arduino/hardware/tool/avr/etc
define motherboard 62
hope this will help u
regards
thomas
Re: It's my Third Motherboard and, I just want my printer to move.... Please Help March 11, 2014 08:31AM |
JOguino
Got the firmware uploaded finally. But.....
it's still not moving.
I'm using Pronterface and have installed it according the instructions on this video.
www.youtube.com
Right when i connect via button on pronterface, it says the following:
Connecting...
1.3.22T / 20.08.2012
start
Printer is now online.
SD Start
SD init fail
Soft PWM Init
Planner Init
Stepper Timer init
Free Ram: 11661
Plan Buffer Size:1152 / 16
When i have the board plugged into the computer.
When i plug in the power supply (atx power supply with the 4 "square prong", "yellow and black" wires) i get the following error:
[ERROR] Can't read from printer (disconnected?) (SerialException): device reports readiness to read but returned no data (device disconnected?)
i noticed the red LED dims a little bit.
When i dont have the board plugged into the computer.
the ATX power supply fan suddenly turns off the moment i plug it into the board.
I lose all power....
I checked the atx with a volt meter and i'm reading 12 volts. IDK why it's doing what it's doing.
Also do i have to have 12V plugged into the power inputs next to the motor inputs? or is the atx power supply enough?
Can someone help me again please?
Re: It's my Third Motherboard and, I just want my printer to move.... Please Help March 12, 2014 09:25PM |
Re: It's my Third Motherboard and, I just want my printer to move.... Please Help March 13, 2014 04:46AM |
Re: It's my Third Motherboard and, I just want my printer to move.... Please Help June 01, 2014 07:07AM |
