compile troubles
June 08, 2015 11:43AM
hello! i try to compile marlin with full graphic display support for my melzi, but i got error in U8glib (which is installed latest version)
i run windows 8.1. x64 and arduino ide 1.5.8. beta. on non beta versions i got forever compile with no success.
without "full graphic display" it compiles fine.
here is my firmware
[www.dropbox.com]
here is the errorlog
[www.dropbox.com]
please help.
Re: compile troubles
June 09, 2015 04:56AM
I have confirmed this issue...
its the marlin your using.
real marlin from [github.com] set to
#define MOTHERBOARD BOARD_MELZI
and
#define REPRAP_DISCOUNT_FULL_GRAPHIC_SMART_CONTROLLER
Compiles without issues for a 1284p... (runs out of space on a 644p)
June 10, 2015 01:31AM
thank you, i checked it - you were right.
June 14, 2015 01:50AM
sad to say i have another problems now! when i try to compile firmware for melzi, i got no error now, but compilling bar just freezes, on like 1/4 forever. i gues that it is something to do with sanguino install maybe. i made it like here. i tried it on my mac but got the same result...
Edited 1 time(s). Last edit at 06/14/2015 01:51AM by Shohart.
June 15, 2015 01:23AM
The ide is a bit buggy
Some errors freeze the display instead of displaying the error
Run the ide from the comand line, when it freezes, send the command line a CTRL C, this will kill the ide, but will also show the error its getting hung up on.
June 15, 2015 05:50AM
Done!
come ultralcd pin errors...
In file included from Marlin.h:21:0,
                 from temperature.h:24,
                 from ultralcd.cpp:1:
ultralcd_st7920_u8glib_rrd.h: In function 'void ST7920_SWSPI_SND_8BIT(uint8_t)':
fastio.h:45: error: 'DIOLCD_PINS_D4_RPORT' was not declared in this scope
 #define _WRITE(IO, v)  do {  if (&(DIO ##  IO ## _RPORT) >= (uint8_t *)0x100) {_WRITE_C(IO, v); } else {_WRITE_NC(IO, v
); }; } while (0)
fastio.h:68:23: note: in expansion of macro '_WRITE'
 #define WRITE(IO, v)  _WRITE(IO, v)
ultralcd_st7920_u8glib_rrd.h:29:5: note: in expansion of macro 'WRITE'
     WRITE(ST7920_CLK_PIN,0);
fastio.h:34: error: 'DIOLCD_PINS_D4_WPORT' was not declared in this scope
                                          {DIO ##  IO ## _WPORT |= MASK(DIO ## IO ## _PIN); }\
PS C:\Users\Алексей> fastio.h:45:80: note: in expansion of macro '_WRITE_C'
); }; } while (0)
fastio.h:34: error: 'DIOLCD_PINS_D4_PIN' was not declared in this scope
fastio.h:17:26: note: in definition of macro 'MASK'
 #define MASK(PIN)  (1 << PIN)
); }; } while (0)
June 15, 2015 05:53AM
it compiles well for mega2560 (ramps)
Edited 1 time(s). Last edit at 06/15/2015 05:53AM by Shohart.
January 24, 2017 05:15AM
Hi
Im running a Gen7 Board-AVR 1.5 with Marlin-1.1.0-RC7 using arduino 1.81(have also tried previous versions of ardiuno)
it compiles and uploads perfectly untill i enable the REPRAP_DISCOUNT_FULL_GRAPHIC_SMART_CONTROLLER
then i start getting 'DIOLCD_PINS_D4_RPORT' was not declared in this scope.
January 24, 2017 06:21AM
Gen7 has no support for a LCD, so unsurprisingly no pin definitions have been setup for it.
If your trying to hack on the GLCD you going to have to create your own pins.h file
Personally I wouldn’t bother... GLCD's use to much rom (all the fonts have to be stored in there, as well as the graphics data) and when running it uses to many cpu cycles, causing blobs in your print. (if you have a 20mhz crystal, ie 25% faster than a mega2560, you may get away with it, i've not tried that combination)
