Does this also Melzi v2.0 for Huxley?
Posted by herisuprapto
January 05, 2016 08:17AM
Because RepRap Pro already closed their shops, I want to buy Melzi v 2.0 here:[www.amazon.com]. Can I use it to Huxley?
Re: Does this also Melzi v2.0 for Huxley?
January 14, 2016 04:10AM
Probably; but have you considered upgrading to Duet electronics instead, as RepRapPro did for their Huxley kits?
Large delta printer [miscsolutions.wordpress.com], Robotdigg SCARA printer, Crane Quad and Ormerod
January 14, 2016 04:17AM
Any standard controller will work.
You just need to configure the firmware appropriately for the machine.
The only gotcha I know of is some have a external heated bed board, which need a 5v logic signal
January 14, 2016 10:54PM
Right now I still want to try Melzi because I'm used to this, for example, when the wiring, but if I have a new printer so I could try Duet or other boards.
I've bought it, but in a different place, but the lights in heatbed no flickering and the surface becomes very hot, also out smoke in mosfet.
