Hi all.
During printing the other day I had my Prusa clone jamb to the extent that it tripped the house mains supply.
On powering up again every thing works except there is no communication via USB. My Laptop doesn't respond (no comport recognition). I have changed the cable. Checked the Laptop is OK by using my other machine.
I have control of the printer via the LCD controls and can print from SD.
Its a Melzi V2.0 board running repetier firmware. Any ideas where it is broken? and how to fix?
I can't find any reference to this failure on the web. I think there is only the connector, TTL (is that the protocol ?) chip and a couple of capacitors before it goes into the processor.
If its the chip can I buy a USB to TTL lead and solder it in place of the on board chip?
Tonight i will check if the processor powers up when the jumper is set to USB 5V to see if the 5V is there. My probes on my MM are a bit to big to measure it off the connector and board.
