connection confusion
Posted by colourz
May 12, 2011 01:09PM
hi everybody,please help me regarding this...
I've made my own mobo v1.2 but did not solder only the atmega644, instead i plan to use a sanguino board I bought premade,now the question is -can I pin the sanguino onto the mobo in the female serial connectors without the atmega644p 20au on the mobo? If so ,to what should I connect the ttl to burn the boot loader,to the mobo serial or the sanguino serial? Will the mobo work as a sanguino?
Re: connection confusion
July 11, 2011 05:24PM
You can't program the boot loader through a serial connector, you need a programmer. If you have an arduino that can be made into a programmer. Otherwise you will have to buy or make one.
