Melzi 2.0 connectivity issues
Posted by HyraxAttax
June 22, 2019 04:24AM
Last week the heat bed of my Reprappro Huxley shorted the power wires, which caused the power adapter to shut off immediately. After screwing down the wires again, I plugged everything back in and got an "unrecognized USB device descriptor" message from Windows. The hotend fan turns on, and the cooling fans twitch, so it appears something is working. I switched the Melzi board to USB power, and tried re-uploading the firmware, which worked. I switched back to external power, but still got the same results. I checked the voltage regulator, and it's sending 4.93v to the ATMEGA1284P like it's supposed to.
I switched the board back to USB and plugged it in, and Windows was able to recognize the device. I can even connect to it in Pronterface, get a response from M503, and the thermistors are returning the correct values.
I can't figure out what's going on here. I set the power jumper to USB, it's recognized. Switch it so that the 19v adapter is sending 5v through the voltage regulator, it's not. I've looked at the board schematics. 5v is being directed through the jumper either way.
Edited 1 time(s). Last edit at 06/22/2019 04:27AM by HyraxAttax.
Re: Melzi 2.0 connectivity issues
June 22, 2019 05:01AM
check voltage going to FT232L the usb serial converter, as this is what your computer is really looking at. It does all the USB stuff
June 22, 2019 08:11PM
USB power only:
Pin 4, VCCIO: 4.43v
Pin 17, 3V3OUT: 3.35v
Pin 20, VCC: 4.43V
Adapter power only:
Pin 4, VCCIO: 4.89v
Pin 20, VCC: 4.88v
Adapter power, USB connected to PC:
Pin 4, VCCIO: 4.87v
Pin 20, VCC: 4.87v
