Just documenting this here.
If you want to upload to a Sanguino(lolu) or Melzi directly from platformio, without using a bootloader
Firstly setup a arduino board as a ArduinoISP as documented here [
www.arduino.cc]
Wire this to the ISP port of your controller.
Now edit your platformio.ini file.
Set default_envs = melzi
In the [env:melzi] section
comment out upload_speed = 57600 with a #
add the following lines. (settings from [
docs.platformio.org])
upload_protocol = stk500v1
upload_flags =
-P$UPLOAD_PORT
-b$UPLOAD_SPEED
; edit these lines
upload_port = SERIAL_PORT_HERE
upload_speed = 19200 #this is the default in the arduino as isp sketch.
Then you need to "Upload using Programmer"
eg use
Edited 1 time(s). Last edit at 04/24/2020 12:12PM by Dust.
