I can't get my ATX power supply to work
Posted by dominsch
September 06, 2015 07:15AM
I got myself a new psu to use with my heatbed. It can power the electronics but when I try to use a stepper motor or a heat element it turns off immediately. The only thing I've done so far is to connect the green wire to ground. Can you tell me what I'm doing wrong?
Re: I can't get my ATX power supply to work
September 06, 2015 08:25AM
You need to put a dummy load on at least the main 5V output of the PSU and perhaps the 3.3V rail as well. Otherwise the voltage on those rails will rise when you load the 12V rail, and the over-voltage circuit in the PSU will trip. See [reprap.org].
Edited 1 time(s). Last edit at 09/06/2015 08:25AM by dc42.
Large delta printer [miscsolutions.wordpress.com], Robotdigg SCARA printer, Crane Quad and Ormerod
September 26, 2015 03:25PM
Ok, after trying lots of different things I accidently found a solution. I had to connect 3.3VS to +3.3V. That's it. Maybe this helps someone...
